Old 01-24-2019, 04:02 PM
9GT's Avatar
9GT 9GT is offline
You can get dacron polyester fabric from just about any local fab store in various weights. When we were building the two Cozy MKIV's at my house, I would even find it on clearance once in a while in the Walmart fabric center for .99 cents a yard. If you use a fabric with a dyed pattern, it will sometimes bleed through though and leave the pattern on your fiberglass part!
David C.
Howell, MI
RV-10: Under Construction
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2020
Old 01-24-2019, 05:45 PM
MonkeyWrench MonkeyWrench is offline
Hi guys. One more question for you all. The term micro bubbles is used a lot. It seems like a generic term. It looks like it just means small glass bubbles. Is it safe to say that the 3M GLASS BUBBLES on ACS is the same thing as the generic micro bubbles?
3M GLASS BUBBLES
https://www.aircraftspruce.com/catal...es/bubbles.php
I'll be using West Systems (I did see Dan's original note on the pumping of the product). Will probably just poor it.
However, West Systems has all kinds of speciality 400 series fillers.
https://www.aircraftspruce.com/catal...stemManual.pdf
It seems that you can obtain the same level of finish as the West Systems 400 series fillers by using micro bubbles and varying the amount micro bubbles you add.
Thanks all!
Rich
RV-14A
working on empennage
EAA Chapter 186
Old 04-12-2019, 05:32 AM
DanH's Avatar
DanH DanH is offline
Sorry Rich, missed your question.
Microballoons are generally available in glass (white) and phenolic (dark red). They are the basic ingredient in almost all lightweight fillers.
The West line of fillers incorporate additional ingredients, most of which are equally common (for example, talc, styrene, and wood fiber). Obviously different blends impart different properties. In my opinion, those property changes are of little value to homebuilders. For sure the West blends are very expensive compared to stocking the shop with ordinary glass micro, flox, and cabosil.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-05-2019, 02:05 PM
ksdflying ksdflying is offline
Wow. Just wow Dan H. Can't give enough appreciation to you for you posting this thread. This is just awesome.
Thank you for the details and the photos!!
Dan K. RV-8 kit purchased 2014, build start Jan 2018, Slow build Emp. done - March 2018, Slow build Wings done -Oct 2018, QB Fuselage started - Sep 2018
Avionics in - April 2019. Engine and Finish kit in hand 2019.
VAF dues paid!
Old 08-14-2019, 09:40 PM
czechsix's Avatar
czechsix czechsix is offline
Default How many plies to glass empennage tips to aluminum?
For those who have glassed in their empennage tip fairings to get the seamless look, how many plies and what ply weight worked well? I like the look but want to minimize weight, and this isn't structural....but a single layer of very thin glass might crack over time due to vibration and different thermal expansion rates between the fiberglass tip fairing and adjacent aluminum surface. So I'm particularly interested to hear from those who have been flying for a while (what has -- or hasn't -- held up over time?).
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 08-15-2019, 08:09 AM
DanH's Avatar
No fabric plies at all. Tips bonded with Hysol, riveted wet, gaps filled with micro. Still doing fine at 875 hours.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-15-2019, 12:05 PM
czechsix's Avatar
Wow, that's amazing...I'm really surprised that you haven't seen any hairline cracks show up where the micro meets the edge of the aluminum skin!
Mark Navratil
Spring Hill, KS
Old 08-15-2019, 03:32 PM
DanH's Avatar
So I'm told. It's an experiment, and may explode any minute.
So, more than a decade ago, why did I think it would work? Here's reality. The tips are cheap polyester glass. The coefficient of thermal expansion is about 14 microinches per inch per degree F. The coefficient for aluminum is typically around 13. There is no significant thermal expansion difference to drive cracking, thus I assumed cracking was merely a function of poor component fixation.
The polyester glass is inside the aluminum flange, and evenly bonded (i.e. evenly stressed), not fastened at individual points. I could have drilled out the pop rivets after the Hysol cured.
Check back in another 800 hours. I'll keep the crow in the freezer.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-26-2019, 10:40 AM
MS19087's Avatar
MS19087 MS19087 is online now
Default Which Hysol is recommended?
Dan - There are many Hysol variants out there- what is the recommended Hysol product for this application?
Thanks!
RV-9A; N91RV Sold
RV-14A; building
2020 =VAF= donor
Old 08-26-2019, 11:56 AM
DanH's Avatar
Originally Posted by MS19087 View Post
Dan - There are many Hysol variants out there- what is the recommended Hysol product for this application?Thanks!
9430 is fine.
Dan Horton
RV-8 SS
Barrett IO-390
