Old 07-12-2018, 12:05 AM
Jake14 Jake14 is offline
Default mixing oils
got some different oils around the shop and don't want to waste them. I heard it's ok to mix. can I randomly put the oils in the pic into my IO-390?
RV-14A #140158 flying
Old 07-12-2018, 05:13 AM
RV6_flyer's Avatar
YES they are all compatible and will do no harm to your aircraft engine.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 07-12-2018, 07:20 AM
go for it, i am definitely a mix ologist. i have put worst stuff in my lyc.
TURBO YES =VAF= Payed Jan2018
Old 07-12-2018, 10:34 AM
rick9mjn rick9mjn is offline
Here is one idea, to use/use up “different oils” .
Before you go to do your standard oil change , add a bit of the “different oils “ to the crank. , so the new,added oil's ,clean/new detergent's , can help clean up your engine,,,,,,,,,,,, which the main idea of changing your oil.
good day rick
Old 07-12-2018, 11:04 AM
Default “different oils” (added bits)
Before you go to do your standard oil change , add a bit of the “different oils “ to the crank. , so the new/added oil's ,clean/new detergent's , can help clean up your engine, which the main idea of changing your oil............
(added bits)..= ...it goes with out saying, add bit of “different oils” ,then warm up engine “go fly” ,then drain/ change oil.........
good day rick
Old 07-12-2018, 04:15 PM
Vlad Vlad is online now
The same here Turbo. Once in a remote country I was running low on oil (3 qts) a case was waiting for me 10 flight hours away. I found a quart for $20 and pushed several hours to a destination where I was able to source some auto oil.
