View Poll Results: What is your combination?
1 13 34.21%
2 25 65.79%
3 0 0%
Voters: 38. You may not vote on this poll
Old 07-11-2018, 05:11 PM
AX-O's Avatar
AX-O AX-O is offline
Default Counterbalanced crank and constant speed prop question.
All,
I am trying to collect data on how many folks are running a constant speed prop with a counterbalanced crank and without a counterbalance crank. depending on the results, I may be working on a project for a constant speed prop (flight test). If you care to provide feedback, reply with one of the answers below. If you care to ellaborate on #3 (if that is your selection), that will deeply appreciated.
1. Counterbalanced crank and constant speed prop.
2. Non-counterbalanced crank and constant speed prop. No prop issues/failure.
3. Non-counterbalanced crank and constant speed prop. Some prop issues/failure.
Thank you for the feedback.
Axel
RV-4 fastback thread and Pics
VAF 2019 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 07-11-2018, 05:21 PM
skylor's Avatar
skylor skylor is offline
Default Engine/Prop Combo
Constant speed (Hartzell) and counter-balanced crank.
Skylor
Toobuilder's Avatar
I'm guessing that you are discussing 4 bangers only? If not, it's going to skew your data
Michael Robinson
______________
RV-8 - Flying
Old 07-11-2018, 08:26 PM
AX-O's Avatar
Good point. I am only refering to 4 cylinder engines. Thank you.
Axel
Old 07-11-2018, 08:31 PM
MConner MConner is offline
Take one off then, I voted counterbalanced with c/s...540
Old 07-11-2018, 08:49 PM
Chkaharyer99 Chkaharyer99 is offline
Titan IO-360 Parallel valve. 9:1 compression.
Hartzell metal blended airfoil with B-hub.
Approximately 800 hours on prop engine combo.
Charlie
RV-8
Old 07-12-2018, 07:00 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
2. (Stroked) non-counterbalanced crank and constant speed prop. No prop issues/failure.
Aerosport IO-375/Hartzell.
Dan Langhout
2019 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
437 hours and counting . . . .
Now based at Moontown (3M5)
Old 07-12-2018, 07:22 AM
airguy's Avatar
airguy airguy is offline
Not a lot of time on it so far, only 260 hours, but non-counterbalanced and Whirlwind C/S here, no problems.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 400 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 07-12-2018, 08:19 AM
DanH's Avatar
DanH DanH is offline
The questions are much too superficial.
Blade failure is a function of vibration, i.e. number of cycles and amplitude. The blade is a victim. Whack it at one of its natural frequencies, and it will resonate. If the resonant vibration exists for enough cycles (think operating hours), or has high amplitude (meaning high stress), the blade will fail eventually. If run at a engine RPM which does not result in significant blade vibration, the blade will be fine.
Mere knowledge of the crank type is useless without also knowing the operating condition. That's why prop manufacturers who actually instrument and test their blades using strain gauge arrays may insist on operating restrictions...an RPM range, or RPM/MP combination, at which operation is to be transitory only. The measured stresses were high in those ranges, so they wish to limit the number of cycles.
In general, plain crank engines result in more prop restrictions. However, the presence of pendulum absorbers does not guarantee a happy prop across the entire operating range. The IO360-A3B6D/McCauley is an example.
Nor is the issue restricted to constant speed props.
In addition, the questions say "constant speed" but do not specify a blade material. Aluminum, composite, and wood blades are very different.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-12-2018, 08:44 AM
AX-O's Avatar
Thanks Dan for the info. I was trying to make a quick poll and a small post so i could actually get data. If someone said “i have had issues”, then i was going to contact the person individually. We have instrumented data for some combos of cranks/props. Just trying to get some feedback from users vice only from a test stand.
Axel
