Old 07-11-2018, 04:29 PM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default Prop RE-balancing
Hi, has anyone had their prop dynamically balanced a second time and found any significant changes?
I had mine balanced about 10 years ago, before first flight. Over the years I feel like my floorboards are vibrating more and more...or maybe I'm just becoming more sensitive. Have tried the usual things of checking for stuff rubbing on cowl, wheel spin, fairings, etc. And all this despite a few layers of foam, carpet, and thin plywood on the floor.
Thanks for any data points!
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 07-11-2018, 06:41 PM
Ralph Inkster Ralph Inkster is offline
Prop wise, if it is in itís same condition as before (no rock chip repairs etc), it should be the same. Engine wise, balancing not only considers the rotating mass, but also takes into account the power pulses, numerous misc small internal parts movements, looseness of exhaust and other bolted on accessories, etc. So in the 10 years wear & tear the whole assembly is probably creating more or different vibrations than what that tight new assembly had originally. Even that(common snag) fiberglass repair to the air filter housing would change the overall mass.
So, dynamic balancing probably isnít a one time ever event.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 07-12-2018, 04:50 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is online now
I balance mine yearly during the condition inspection, and there are usually minor changes. I attribute this to wear, as mentioned, and also small balance changes due to dressing the aluminum prop blades when needed.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 07-12-2018, 07:07 PM
Jesse's Avatar
Jesse Jesse is offline
Removing and reinstalling the spinner can be enough to change the balance.
352-427-0285
jesse@saintaviation.com
Old 07-12-2018, 09:47 PM
Walt's Avatar
Walt Walt is offline
Dynamic balancing can only correct the rotating mass imbalance of the propeller assy, which would include the flywheel, spinner and spinner bulkhead, and associated components. It cannot correct anything else. It can only change if something mechanical changed that would alter the balance.
I've rebalanced my own prop a number of times over the years just to "check" it but have never seen a significant change in vibration levels.
After 10 years I would be much more suspect of the engine mounts, especially if they were the Van's mounts. Engine mounts wear out and will transmit more and more vibration to the airframe.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 08-08-2018, 11:22 PM
TurnsWrenches TurnsWrenches is offline
^This!
Check your mounts for eccentricity and drift first. If they are sagged out, they will cause headaches.
Periodic Dynamic rebalancing is a good idea, especially if you can carry out the work yourself. Just make sure you do it properly, in cruise.
Old 08-09-2018, 07:23 AM
mcgaughy mcgaughy is offline
Companies such as Powerflow exhaust recommend rebalance every two years or so. I dynamically balance props and absolutely see changes over time. While I’m not certain, I believe things such as cylinder wear, spark timing / strength, etc can contribute to a dynamic balance. Bottom line real world experience tells me that having a dynamic balance done ever 2-3 years is wise....or whenever major maintenance is done like reclocking props, cylinder work, overhaul, etc.
Ellis
Final Approach Aviation LLC
A&P / IA
Old 08-09-2018, 09:48 AM
FasGlas's Avatar
FasGlas FasGlas is offline
Tip: Before balancing a constant speed prop make sure you fill the grease ports (as per manufactures procedures). The weight of the grease can effect the balance and it changes as the grease slowly leaks out. A full prop is always your reference point.
Old 08-09-2018, 10:06 PM
Tankerpilot75 Tankerpilot75 is offline
Donít want to steal this thread but typically what does it cost to have a C/S prop balanced?
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS)
Retired - Living the dream - And going broke!
Old 08-10-2018, 05:51 AM
Walt's Avatar
I charge $250 for experimental, owner RR's the top cowl.
