Old 07-09-2018, 08:13 AM
Carl Froehlich's Avatar
Default Canopy intersection fairing
It’s that time again - laying up the canopy fairings.
Years ago on the first 8A project I used electrical tape on the canopy as the release agent. That seemed to work well but now I read the warnings from Van’s not to use electrical tape as it can cause crazing.
The instructions call for Mylar tape or release agent. I’d be interested in what builders are doing now and what they recommend.
Old 07-09-2018, 08:43 AM
sf3543 sf3543 is offline
Default Things that have worked for me
I have used clear packing tape, Saran Wrap and the clingy static plastic used to wrap furniture when you move.
The packing tape works great but usually leaves a sticky residue you have to clean off later.
On aluminum, if the blue protective coating is still on, I will just lay up directly on that and put packing tape over any rivet lines or holes where it was removed. Works great.
A heavy coating of wax will also work, although I prefer the former methods.
Steve Formhals
RV6, RV8 (2), RV12 & RV3
A&P, Tech Counselor & Flight Advisor
Old 07-09-2018, 09:49 AM
rv8ch rv8ch is offline
Originally Posted by Carl Froehlich View Post
...Years ago on the first 8A project I used electrical tape on the canopy as the release agent. That seemed to work well but now I read the warnings from Van’s not to use electrical tape as it can cause crazing. ...
First I've heard of this - any idea why electrical tape can cause crazing? Something in the glue? Mylar packing tape comes from so many sources, I would struggle to ensure that it does not have the same glue as the electrical tape.
Mickey Coggins
http://rv8.ch
Old 07-09-2018, 09:59 AM
This was posted on another thread - and that got me to wondering: https://www.vansaircraft.com/pdf/Acr...ndow_Hints.pdf
Old 07-09-2018, 11:25 AM
Lars Lars is offline
If you use clear packing tape, be advised that they aren't all created equal. The adhesive on some will remain on the surface rather than releasing, and it can be incredibly difficult to remove. In my experience 3M works better than anything else I've tried. More expensive, but worth it for the savings in aggravation.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
700+ hours as of October 1, 2018
Old 07-09-2018, 01:35 PM
The article that Carl linked to says not to use the tape on Lexan, but it doesn't say that for acrylic. I think that the canopies are acrylic.
Old 07-09-2018, 03:48 PM
Larco Larco is offline
I have used electrical tape in layers while doing the fiberglass work necessary to finish several canopies. Started in 1995 and others as years went by. Whats up with not using electrical tape??
Old 07-09-2018, 04:34 PM
Yep - that could be my mistake.
