Old 07-09-2018, 11:16 PM
jliltd jliltd is offline
If you are set on connectors I woukd encourage using Deutsch weatherproof DTM or DT connectors. They are awesome and sealed from the environment. More so than the round plastic type. Similar to automotive Weatherpack or connectors just higher quality and full barrel pins for reliability and ease of crimping and installation.
RV-8
RV-3B
Old 07-09-2018, 11:37 PM
RandyAB RandyAB is offline
These are my preference too but I just canít seem to get past the large cost of the crimper.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 07-10-2018, 12:08 AM
bruceh's Avatar
bruceh bruceh is offline
I left the wiring coiled up in the fuselage until I attached the wings. You can easily pull the wires out to the wing tips and connect them up after the wings are on for good. I just left a service loop in the fuselage and IF the wings ever need to be removed, I will cut the wires then, or just pull them back into the fuselage. Connectors add failure points and should be used only when absolutely necessary.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 07-10-2018, 12:17 PM
DRMA DRMA is offline
Mark,
I have run the lighting wires (nav, strobe, landing, & taxi) from the panel switches to a terminal strip mounted on the rear seat front bulkhead. From there the wires split and run to the tail and out to both wings. This provides for the amperage required by the lights, and with ring terminals makes for a tight connection. The terminal strip will be covered by the flap actuator/torque tube cover.
I have pulled the heavy gauge wires that will power the pitot heater from the panel back to the left wing area and coiled them, and will pull them to the pitot tube after the wings are attached using a pull string installed in the wing.
The wires for the auto pilot servo and trim servo will be connected through a small D-sub connector. However, the CAN Bus wires will be run continuously from the pitch or yaw AP servo out to the wings where it will connect to the magnetometer and then on to the roll servo, without an extra connector at the wing root. If you want to run the CAN bus wire through an extra connector, I suggest you talk to Garmin regarding the type of connector and advisability of making such a connection.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
