Old 07-07-2018, 11:04 AM
bobhope2505 bobhope2505 is offline
Default Mysterious holes in QB wings--inboard rib
I'm about to install the wings, but there are a series of holes in a diagonal pattern in the inboard rib in the aft most part--maybe 14 or so but I don't have it in front of me right now. It REALLY looks like a bracket goes there, but I have scoured the plans looking for some instructions and can't find any. I find it hard to believe that Van's would go through the trouble of putting those holes there without a reason. Did I miss something? If so, can you provide any direction?
Syrus
RV-14A
Air frame complete
90% done, 50% to go...
Old 07-07-2018, 11:13 AM
Mudfly Mudfly is offline
Hello Syrus,
I believe those holes are for flap brackets. I don't have wing plans in front of me, but as I recall that inboard rib is the same used as some of the inboard ribs just no flap bracket installed.
Pic here?
Shawn
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 07-07-2018, 01:03 PM
Yep. Those are the holes.
RV-14A
Air frame complete
Old 07-07-2018, 02:18 PM
RV-14E's Avatar
RV-14E RV-14E is offline
The original demonstrator, N214VA, has three flap brackets. The kits have two. This is evident in this picture I took when I visited the home base several years ago.
I would hazard that the inboard ribs, W-1010-L/R, remaining is a consequence of the change.
E
http://rv-14a.blogspot.com/
Old 07-07-2018, 03:08 PM
Mystery solved! To back that up, I went back to the inventory sheets and verified that no 1025B flap brackets were included with the kit.
Thanks!!
RV-14A
Air frame complete
