Old 07-03-2018, 06:54 PM
JwWright57 JwWright57 is offline
Question ES-00079 floating connector crimper?
hi all - i'm at the point where i'm working on the wing connectors and need to crimp the ES-00079 floating connector. What the heck do I do that with? A google search came up with zilch....
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit in progress
Dues paid 2019
Old 07-03-2018, 07:11 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Have a real part number and manufacturer, or a photo?
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
Old 07-03-2018, 07:23 PM
Bob Y Bob Y is offline
Working on my wing kit now and will be terminating those within the next week or so. I intend to use this:
https://www.showmecables.com/d-sub-crimp-tool
It's what I used to terminate the MOLEX pins for the trim servo connector too - they were just a lot smaller.
Old 07-03-2018, 07:27 PM
MMiller MMiller is offline
All the info you will ever need on the Amp contacts used in these floating connectors;
https://drive.google.com/open?id=0By...UNZZzA2aFByYlE
Van’s suggestion for a crimping tool can be found on page 24 of section 5;
http://www.vansaircraft.com/pdf/revisions/RV-ALL_05.pdf
Old 07-03-2018, 07:54 PM
wow MMiller that is some crazy detailed information! Thanks a ton.
Rv-12 started!
Tail 99% done
Wings 99% done
Dues paid 2019
Old 07-03-2018, 08:03 PM
rongawer rongawer is offline
Default Excellent crimpers
Hereís the crimpers Iíve used for everything molex, even the straight-from-china Hilitchi molex-copies. Itís a low priced, very accurate tool that ratchets nicely. IWISS makes good stuff.
IWISS Crimping Tools for Dupont Professional Pin Compression Ratcheting Modular Insulated Terminal Crimper Pin 2.54mm 3.96mm 28-18AWG 0.5-1.0mm2 with Wire-electrode Cutting Die https://www.amazon.com/dp/B00OMM4YUY/ref=cm_sw_r_cp_tai_CWbpBb5KQZ24E
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
