Old 06-30-2018, 08:39 PM
larrys larrys is offline
Default A couple questions on the fuselage build
On page 34-2 it calls out a template W-00026 to get the angle for the flap rod. It was not on the ship list. Is it something I need to order or make?
On the rods for the flaps, they do not fit through the black blocks F-1030. Do they need to be reamed out? Or am I missing something? The powder coating is much thicker then the rod by it self. The rod fits in tightly but it will not slip over the powder coating.
When installing the pedals I used the holes closet to the firewall because we could use the length because of the height of my partner who is building the plan with me. The question is will the pedals still have the full swing needed?
Thanks in advance for help!
RapidsetBuildings.com (Hangars)
Advertiser
RV-14 tail, QB Fuselage, Finish kit, QB wings and FF kit
Grateful to pay dues 19'
Old 06-30-2018, 09:03 PM
YoVuelo YoVuelo is offline
If I remember correctly, that is a part that comes in the wing kit. Easiest way to go would probably be to see if you can order one from Vans while waiting for your QB wings to arrive.
As to the flap actuation rods, they fit snug, but with a little bit of a twist and a touch of boelube they went through the blocks. I was mightily impressed when they lined up perfectly when the rod was finally installed from the outside. Though they were snug, there was no binding or anything when I tested them with the flap motor.
YoVuelo-Tucson, AZ
RV-14A Kit 294
Empennage Started 5/23/16 - Comp. except fiberglass
Wings - 95%
Fuse - 98%
Old 06-30-2018, 09:32 PM
mturnerb mturnerb is offline
Indeed the alignment tool is part of the wing kit. It costs about $12 and can be ordered from Vans separately.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
