Old 06-29-2018, 12:37 PM
patmiller patmiller is offline
Default RV-12 as a technically advanced aircraft
Sure looks like I can use my -12 for commercial and CFI training... Dynon Skyview seems like it meets the FAA's definition of PFD/MFD
The new rule offers an alternative to meet the previously required 10-hours of complex aircraft training to be met by “any combination of turbine-powered, complex, OR technically advanced aircraft” (TAA). A TAA aircraft is defined as an aircraft that has “an electric Primary Flight Display (PFD) that includes at a minimum, an airspeed indicator, turn coordinator, attitude indicator, heading indicator, altimeter, and vertical speed indicator and an electronic Multifunction Display (MFD) that includes at a minimum, a moving map using Global Positioning System (GPS) navigation with the aircraft position displayed, and a two-axis autopilot integrated with the navigation and heading guidance system.”
RV14-A
*empennage done for now
*wing kit nearly done
*fuselage kit just arrived!
RV12
* to distract me while building the -14!
Exempt, but 2017 dues paid anyway
http://N414PJ.wordpress.com
Old 06-29-2018, 04:01 PM
dtw_rv6 dtw_rv6 is offline
Yeah... I have to question whether their definition lives up to Technically Advanced. Maybe it should have been designated as “Modern / commonly found in new GA aircraft”.
Old 06-29-2018, 05:40 PM
Always fun to speculate on English words that are strung together and no longer have English meaning (as in FAA docs).
The quote does say, 'combination of'...
So, turbine+complex? Turbine alone? Complex alone? Complex+technically advanced? Technically advanced alone? Turbine+technically advanced?
Old 06-29-2018, 09:36 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Any combination of OR ....
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
