Old 06-28-2018, 10:11 AM
Charles in SC Charles in SC is offline
Default Tachometer drive question
I am hooking up my tach which is Van's analog 2 1/4 model and the engine end is a cable about 10 inches long with a sensor that screws on the end of it. The problem is that the firewall causes the cable to have to make a sharp 90 degree bend and lays pretty hard against the firewall. This might not be a problem but I would like to find a better way if possible. Does anyone have a more graceful solution? Thanks in advance!
Aircraft structure built.
Going at a snail's pace, life gets in the way.
Wiring done.
Engine hung.
Working on cowling.
RV 7
Old 06-28-2018, 10:50 AM
gasman gasman is online now
Mount it down in the lower left side of the recess using a standoff for perfect fit.
VAF #897
2019 =VAF= Dues PAID
Old 06-28-2018, 09:33 PM
I will have to look harder maybe but I do not think there is but one place to attach it. The tach drive point is just above the right mag.
Wiring done.
Engine hung.
Working on cowling.
RV 7
Old 06-29-2018, 04:45 PM
My fault....... I should have said.......
recess in the firewall is where you would mount the tach signal driver that hangs off of the end of the 12 inch extension.
VAF #897
Old 06-29-2018, 09:04 PM
Thanks, I figured that out today.
Wiring done.
Engine hung.
Working on cowling.
RV 7
