Old 06-25-2018, 07:20 PM
Tmartin66 Tmartin66 is offline
Default Beringer Master cylinder length
OK folks, I'm installing Beringer brakes on my 14A and I'm trying to determine what dimension to set my length at on the master cylinders. Center to center on the rod ends connected to both ends of the master cylinder. Thought a good length to start with would be the length of the stock master cylinders that Vans supplies with their kit as they, from what I have seen, do not have any adjustment. Does anyone know what that length is? Thoughts anyone?
T. Martin
RV-14A under construction
N114TM reserved
Dues paid 2019
Old 06-26-2018, 10:01 AM
Tony---I just have a mockup master here that Carla sent me. Its at 7.25 C/C now. Dont have a set of 14 pedals to check it with.
Tom
Ridgeland, SC
Old 06-26-2018, 10:23 AM
mturnerb mturnerb is offline
I just installed per Berenger instructions - length wasn't much of an issue as far as I recall. Here are some photos on my blog:
https://turnerb14a.blogspot.com/2017...n-section.html
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 06-26-2018, 05:24 PM
HHKing HHKing is offline
Default Matco Master Cylinder Length
I installed my Beringer Master Cylinders after measuring the Matco ones. They measured 7 & 15/32". I think I called it 7 & 1/2 and put them in. Seems to be a good length.
Old 06-26-2018, 08:41 PM
Default Thanks Guys
Thanks to all who responded. I appreciate the input.
T. Martin
N114TM reserved
Dues paid 2019
