Old 06-21-2018, 01:33 PM
Carl Froehlich's Avatar
Default 90 degree main gear valve stem
Iím not having any luck finding a replacement main gear innner tube with a 90 degree valve stem. The objective is to be able to air the tires with a valve extension through the well pant.
Anyone find a source?
Old 06-21-2018, 03:14 PM
BigD BigD is offline
LIke this?
https://www.desser.com/Aircraft-Tire...SS-GL-7087.asp
N102FM
Old 06-21-2018, 04:07 PM
Yep, but need it in the RV-10 main gear size, 15/600-6.
Old 06-21-2018, 04:16 PM
Super Moderator
Default Spruce Michelin Aviator
Spruce has them:
https://www.aircraftspruce.com/catal...?clickkey=7940
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 06-21-2018, 04:41 PM
https://www.desser.com/Aircraft-Tire...SS-GL-1587.asp
that's better..
Old 06-21-2018, 04:47 PM
Originally Posted by BigD View Post
Well shoot fire - how did I miss these?
Thanks Dave,
Old 06-21-2018, 07:09 PM
TomSpencer46 TomSpencer46 is offline
Default Why does Vans do this?
I still am in the build process. wings, fuselage, done. Engine hung and up on the wheels "Matco" the valve stems from Vans are straight and miss the axle nut by less then a 1/8 inch. The nose wheel tube was a 90 degree. Why not all three?
RV-10 started 11/15 N90Vt Reserved
1947 Bonanza 25 years flying
Home field (Spencer) VT09
Old 07-01-2018, 07:36 AM
Plummit's Avatar
Plummit Plummit is offline
Originally Posted by vic syracuse View Post
Am I reading this right? The price doubles for a Mich tube with 90 degree valve stem?
-Marc
N814RV
2018 Donation made!
