Old 06-21-2018, 01:21 PM
EXTAAFLY EXTAAFLY is offline
Default Fuel Fluid Fitting Clocking. 31-05 / 31-11
Iíve done a few searches and scanned down about 5 pages. No luck finding what Iím looking for.
Installing the firewall fuel fitting. On page 31-05 it says to install the fitting with tank sealant on the flange and clock it at approximately 25 degrees from horizontal. Then on page 31-11 it has you adjust the clocking to 40 degrees from the vertical tri gear) when installing the F14109C Pump-Firewall fuel line.
Pretty limited in my ďtank sealantĒ knowledge base. If itís installed and clocked the way it is called for on 31-05 is it going to be able to adjust to the call out on 31-11? Seems to me the sealant on that flange would keep it in place and prevent movement. Should I just install it the way it is called for in its final clocking position?
Jason
ATP - CFII/MEI
RV14A #140419
Tail Cone & Empennage Done'ish 11/18/17 Synergy Assisted
Fuselage - working on it. Wings - later
Finish - It's sitting here in a big box
Engine - Ordered from an undisclosed builder, ready summer 2019
5/13/18 Donated
Old 06-21-2018, 01:42 PM
rvmv rvmv is offline
You may want to consider just putting it on finger tight until you get your engine hung. Then you can clock it the way you like with the fuel line to the fuel pump in place.
Old 06-21-2018, 03:43 PM
Tom023 Tom023 is online now
I posted the same question and never got an answer after it was sealed at 25 so I left it. Went to install hose and lined up perfectly.
RV14A #140083
Down to last 5%.
2018 Donation
