Old 06-20-2018, 06:11 PM
PMLviator PMLviator is offline
Default battery discharging
Ten minutes into my flight I noticed that the battery was discharging, down to 12.9. volts and 7 amps. I turned off both landing light and nav strobe lights. Volts started to climb to 13.9 and amp charge of 11. Dynon 'caution' displayed "battery missing/ fault". Is this the beginning sign of a bad VR, only have 4.7 hours on the plane?
Any help or ideas would be appreciated, Thanks.
Old 06-20-2018, 07:04 PM
tomkk's Avatar
tomkk tomkk is offline
Those were the symptoms I had with a bad VR.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 06-21-2018, 12:06 PM
Slane Slane is offline
Default VR connections
Check to see if your VR connections are good.
Scott Lane
Hillsboro, OR
RV12 Completed & Flying 2013
#120043 N728SL
VAF paid 2018
Old 06-21-2018, 12:42 PM
4.7 hours... I think you win title for shortest life for a Ducati voltage regulator.
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 06-21-2018, 07:08 PM
Angry
Thanks Jim, but it's not the title I want to hold.
Checked the connection and charged the battery. Started the engine and gave it a few minutes. Still showed battery discharging, is it really the VR?
Old 06-21-2018, 07:28 PM
For about $20 on eBay you can try this...http://www.vansairforce.com/communit...0&postcount=52
Hinckley, Ohio
EAA #499867
Old 06-22-2018, 11:09 AM
BigJohn BigJohn is offline
4.7 hours? Warrantee?
“Master Pilot” Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
