Old 06-19-2018, 11:14 AM
schaplerrh schaplerrh is offline
Default Tosten Grip in RV7?
I'd like to put Tosten Grips in my 7 but reading all the post re panel clearance I'd like to see some pics of what you have done to address this problem in a 7. Most of the posts concern RV10, but as you know they have a different stick configuration. Send me a PM with your email and I'll reply to your email if sending pics via email is easier. Thanks. Robert
Old 06-19-2018, 11:56 AM
622BH 622BH is offline
Default Cut the Stick
I had to cut the sticks down by two (2) inches to get clearance for my Infinity grips in a 9A. Now flying for three years, I wish I had cut it down three. Doing so would permit comfortably resting my forearm on my thigh throughout all flight regimes. Recommend you sit in the cockpit, rest your arm on your thigh while holding the grip next to the stick and mark where the base of the grip meets the stick. Then measure up the necessary amount to provide secure mounting of the grip.
Also, make sure you “ clock” the grip so you grip it naturally during flight. If you align it straight forward your wrist will be bent uncomfortably.
Old 06-19-2018, 12:07 PM
Raymo's Avatar
Raymo Raymo is offline
I too have the Infinity grips and had to cut 2-3 inches off the stick but very happy with the setup. The Infinity grips slide over several inches of the stick where the Tosten (I believe) is mostly attached to the top of the stick with not much stick inside. This would require more stick trimming, which might be where the curved stick in the -10 could be a problem.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 06-19-2018, 12:53 PM
bruceh's Avatar
bruceh bruceh is offline
Just take the standard length of the Van's stick tubing and subtract off the length of the new Tosten grip above its mount and that is how much to cut off. You can even go a bit lower. Just make sure you clear the controls with the panel and subpanel for the throttle/mixture/etc. 2-3 inches is not enough to clear the panel.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 06-19-2018, 02:30 PM
airguy's Avatar
airguy airguy is offline
I put the Tostens in my 9A, like others I had to cut about 2" off my stick length to clear the panel. I initially put the grip in place on the full-length stick, ran it up into contact with the panel, and measured "about that much" to cut it off.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 06-19-2018, 03:25 PM
Tankerpilot75 Tankerpilot75 is offline
I installed Tosten military style grips in my RV7A two years ago. Like everyone else I had to cut around two to three inches off my stick. Used a pipe cutter to make the cut. I love these grips!!!
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS)
Retired - Living the dream - And going broke!
Old 06-19-2018, 04:54 PM
tgmillso tgmillso is offline
I'm installing the Tosten military, and had to cut about the same amount off. I wouldn't have minded cutting a little more off, however the palm support at the bottom ends up slamming into your leg at full roll deflection (and I have skinny legs). The other thing to watch is conflict with the throttle control at idle, and mixture for the right stick. The head on the military grip is pretty wide, so I had to change the engine control bracket angle slightly. The CS-8 has a different style head, so hopefully this conflict is not such an issue.
Tom.
Old 06-19-2018, 06:52 PM
Berchmans Berchmans is offline
Default Grips
Be sure and leave room for you thumb on top of the grip.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2019
Old 06-19-2018, 08:37 PM
rzbill's Avatar
rzbill rzbill is offline
As the previous posters said, cut off the equvalent length of the grip. You may have to cut a bit more after checking throttle clearance. I did.
One thing not mentioned is rotating the grip to fit the left hand in its natural rest position. I did and it 'feels' completely correct while flying. There is little reason to point the grip straight forward.
My passenger stick is the stock vans unit with a rubber grip. PTT on the panel. With no Tosten there, no concern about which way to point it.
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 06-19-2018, 09:15 PM
pilotkms pilotkms is offline
Default TOSTEN CS-8
This model, pictured in Bruce Hill's post above, has a swivel mount. This removes the alignment angle others have mentioned above. It swivels to wherever your hand is comfortable while flying. A nice benefit.
Check out his build site. He also made his co-pilot stick removable with functioning buttons. a VERY NICE feature I copied. Thanx Bruce.
Keith
RV 7A RV #9700
N325KS the Flying “K”
Built in SoCal KCCB, now @ KPXE
270+ Hours & 5x cross the USA
2018 OSH - yes
