Old 06-17-2018, 10:48 AM
bobhope2505 bobhope2505 is offline
Default EFII fuel pump installation ?
If you installed the EFII system, where did you mount the dual fuel pump? Stock location or somewhere else? Either way how did it workout?
Old 06-17-2018, 12:02 PM
Default Pumps
I mounted my pumps on the left side tunnel wall and installed an access panel on the right wall. Made the plumbing easier... canít say how it is going to work as Iím not flying yet...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 06-17-2018, 01:24 PM
Thanks for the reply. Noticed the Barrett engine. I did same. Mine arrives in two weeks with the EFII installed by them. Good luck.
Old 06-17-2018, 02:56 PM
which plane?
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 06-17-2018, 03:30 PM
The RV-14A
Old 06-17-2018, 03:50 PM
sbalmos's Avatar
sbalmos sbalmos is offline
Was going to say. 14 must have a different tunnel than the 7/9. I installed mine right on top of the center tunnel cover in my 9A. Basically turned the tunnel cover into a mounting deck. Put in a nice thick .050 plate under the tunnel cover as a reinforcement doubler. And no, no version of the doghouses would cover it. Itís just exposed for now until I fashion some kind of cover.
Scott Balmos
Butler County Airport, KHAO
RV-9A Slider N112SB
Started 1/12/12, Airworthy 6/4/18, First Flight 7/4/18
Build Time - 6.5yrs
IO-320 w/EFII and Catto 3-blade
Beringer brakes/wheels/tires
Dual G3X Touch (Stein's bankrupted me!)
In Phase 1
=/\= 2018 Donation Paid =/\=
Old 06-17-2018, 04:06 PM
Nice build! That'll get you anywhere you want to go. That sounds like some interesting bends in the fuel lines. Did you bend aluminum tube or use flex line?
Old 06-17-2018, 04:17 PM
sbalmos's Avatar
Everythingís flex, done by Tom (TS Flightlines). He has my specs. Iíll fish out my pics from Google Photos later when Iím back home.
Scott Balmos
RV-9A Slider N112SB
Build Time - 6.5yrs
In Phase 1
Old 06-18-2018, 07:08 AM
Syrus---if you are using a EFII injection with a RV14A, YES you can mount the pump. Thats easy---the extra set of rigid tubes from the Andair Duplex valve to the side bulkhead fittings---well not so easy. And the tank connection tubes to the fuse bulkhead fittings---not so easy.
That conversion does take alot of thought, planning, and more planning. Steve and I have done a few 14's with the SDS pump. "Similar" pump configuration to the EFII.
Tom
Ridgeland, SC
Old 06-18-2018, 07:20 AM
219PB 219PB is offline
I also mounted mine in the cabin, on the floor. I plan to build a cover for them as well.
Mine in not flying yet. Few more months to go.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
