Old 06-16-2018, 06:58 PM
ianneub ianneub is offline
Default Maximum Wind Limitation
Hi All,
I recently purchased an RV-12 and have been having a great time getting to know the plane and flying as much as possible.
I've looked around in this forum, but I haven't seen anyone discuss this figure I saw in the POH:
Maximum Wind Limitation 30kt
Does this limitation apply in all situations? Or only for take off / landing?
I've flown in some winds now that showed 20kt+ according to the D180 calculation.
With the lightness of this airplane, I'm worried that a wind gust might hit and flip the plane over. On the ground 30kt is well past my personal limitation. So I shouldn't be in that situation. But what about in the air, at altitude?
Do other RV-12 pilots worry about that?
Thanks in advance for your input!
RV-12
Harvey Field (S43)
Old 06-16-2018, 07:11 PM
To answer your question… once an airplane is flying It doesn’t care about wind direction or speed - turbulence becomes the deciding factor. The airplane simply flies within the moving air mass. Groundspeed is directly affected by both wind direction and speed. Wind becomes a factor, as you point out, during ground operations and when the plane transitions to/from the hard surface.
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 06-16-2018, 07:44 PM
DHeal DHeal is offline
The strength and direction of winds aloft are also important when flying in mountainous areas. Maintaining an appropriate altitude above ridge lines during high wind conditions is prudent. The low wing loading of the typical LSA usually means that you will be more susceptible to the effects of turbulence and varying air currents than heavier, high wing loading aircraft. The modest performance that is typical of most LSAs at higher altitudes requires a very good understanding of mountain flying techniques.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 700+ hours (as of Nov 2018)!
VAF donation through June 2019.
Old 06-16-2018, 09:59 PM
I once climbed up very high crossing water to be within gliding distance of shore. There was a 50 knot cross wind according to the D-180. My RV-12 flew just fine. It thought the air was calm. But it took forever to cross the water.
Joe Gores
RV-12 Flying
Old 06-17-2018, 06:09 AM
tomkk's Avatar
tomkk tomkk is online now
Couldn't agree more. I wonder why Vans put the 30 knot limitation in the POH?
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 06-17-2018, 08:31 AM
Sam Buchanan's Avatar
been here awhile
Maybe due to turbulence below 1000' AGL that 30 kts of wind could generate?
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 06-17-2018, 08:49 AM
Default interesting
Call van's and ask them...as has been previously posted, once airborne, the airplane moves within the airmass and the wind makes no difference...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 06-17-2018, 10:21 AM
DaleB's Avatar
DaleB DaleB is offline
I can't imagine that any wind limitation doesn't just refer to surface winds only. It's not unusual at all to see 40 to 50+ knot winds aloft around here, even at relatively low altitudes. I have a screenshot from a friend who borrowed the plane showing 201 MPH ground speed on the way to FL - that's a 63 knot tailwind.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 06-17-2018, 11:41 PM
Smile
Thank you all for the great comments!
RV-12
Harvey Field (S43)
Old 06-18-2018, 04:10 PM
JonJay's Avatar
JonJay JonJay is offline
It is really embarrassing to have to call the tower, shut down, get out, and push your airplane around because you didn’t have the power to turn it out of the wind. It is equally embarrassing to have to call the tower, shut down, and beg for help to get a few guys to “walk” your airplane off the taxiway.
30kts is a lot of wind on the ground to try to safely taxi any RV.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
