Old 06-29-2018, 09:40 AM
JonJay's Avatar
JonJay JonJay is offline
Originally Posted by Adam W View Post
thank you this has been reassuring and helpful
can anyone comment on the amount they lowered the top cowl to compensate for engine sag?
It is really difficult to determine how much, if any, sag you will get. Some don't sag at all. Some drop a bit.
In the day, folks felt it was a sense of pride to have as little gap as possible. Over time, vanity lost out over ease of use and folks started accepting a larger gap. The larger the gap, the less noticeable the sag will be, if it does sag. It is also much easier to put on and remove.
Others can chime in, but 1/4" gap would be an absolute minimum. I would accept more. I gapped to 1/8" on the top and 5/16" on the bottom hoping for the sag to even out to 1/4" gap. My engine never sagged. I still have the same gap, which frankly isn't noticeable unless you go looking.
As far as top alignment, I think it is important that the transition from the top of the cowl to the spinner makes a nice profile but it is also needs to be centered to the cowl. There is a bit of compromise here and the "gap" plays into how that looks. Sag doesn't come into play as much in regard to the profile unless it really sags a bunch.
I hope others can add to this.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-29-2018, 10:07 AM
RV6_flyer's Avatar
Originally Posted by RV7 To Go View Post
Can't speak to the latest cowls but I had about 2" to cut off the back of my cowls (2008 kit) with the standard extension. I would suggest no less than 3/8" clearance from the back of the spinner to the cowl. Any less and it becomes difficult to re and re the cowl. One of the guys who has built 8 or 9 RV's leaves 1/2" for this reason. I split the difference between Vans 1/4" and his 1/2" and did 3/8" which worked out ok. I had a 4 with a 3/16" gap and it was a pain getting the bottom cowl on and off. FWIW.
Al
20 some years ago, I built my RV-6 with 3/8" space between back of spinner and front of cowl. IMHO, that is the minimum space needed to get my cowl on and off.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-29-2018, 10:38 AM
Carl Froehlich's Avatar
Originally Posted by Wunderon View Post
Somewhat related, when drilling the top hinges to the cowl, is it best to hold the ‘slack’ out of the hinge due to the .090 pin‘s sloppy fit, or let it ride in the ‘middle’ of the hinge eyes where it wants to?
Seems like the cowl would end up loose if you don’t hold the hinge separated, but that might make it hard to put on and remove.
Another option, use 1/8” SS pins for the top cowl. You need to tapper the last 8” or so to .090” or so to make the curve. I did this and it eliminated the top of the cowl riding up on the hinge slack that you get by using the 0.090” pins.
The hard part is doing the tapper. I chucked up a lenght of 1/8” pin in the drill press and had it run on slow speed. I used a die grinder with a rotary file to make the tapper. Cleaned it up with some sandpaper then trimmed the length. The SS is tough - this took some time.
Old 06-29-2018, 12:51 PM
JonJay's Avatar
My neighbor did this as well Carl. He used a disk grinder and it went pretty quickly. Chucked up the rod in a drill as well. Good suggestion.
I just let mine ride up. Doesn't bother me a bit, but this is an easy "fix" if it does.
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-29-2018, 12:52 PM
JonJay's Avatar
I wish I had 3/8". Fortunately, the 5/16" I have is on the bottom.
It is a bit tricky but obviously doable. I like your recommendation. 1/4" is really tight.
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-02-2018, 10:38 PM
Wunderon's Avatar
Wunderon Wunderon is offline
I’m having trouble visualizing how the cowl is ultimately supported in the front. Do the baffles end up supporting the weight of the cowl, with the hinges mainly holding position? Or, should I fit the hinges so that they support 100% of the cowl weight,
prior to installing baffles?
Should I remove my front supports only after all hinges are fitted?
thanks, I’m feeling dense,
dave
Dave Grimmer
RV8 firewall forward
Edmonds WA
paid 2018
Old 07-02-2018, 10:44 PM
dave
The cowling is a self supporting structure. Between the hinges which hold it to the firewall, the hinges along the sides of the cowl, and the screws on the inside of the spinner, the cowl is supported all around and quite rigid. Neither the baffles or engine are part of the support structure for the cowl.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-03-2018, 08:05 AM
rocketman1988 rocketman1988 is online now
Default And
...nor should the cowl be attached to the engine. One look at how much that engine moves will illustrate why...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 07-03-2018, 08:54 AM
Wunderon's Avatar
Thanks, makes sense.
Why I ask is that after I drill the top hinge, and remove the front supports, the front sags below where I want it on the spinner. This is prior to trimming the bottom cowl. Should I leave the front cowl supports in until after the cowl bottom and sides are trimmed and drilled?
thanks
Dave Grimmer
Edmonds WA
paid 2018
Old 07-03-2018, 08:59 AM
BillL BillL is offline
thanks
Definitely keep the front in line with where you want it for the lower cowl fitting process. With just the aft hinge holding it, the sides will bulge out under it's own weight. Just make sure nothing is forced into place when final fitting. Taking the whole thing off and on a few dozen times is normal, at least it was for me.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
