POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
07-04-2018, 09:57 PM
Rob,
I’m not sure I follow the regulatory trail to the ASTM. The Operating Limits for my ELSA allow night and IFR operations if properly equipped. Are you referring to SLSA RV-12s?
Rich
09-17-2018, 01:47 PM
moderator
I have read this thread with great interest as I am seriously considering an RV-12iS project that I specifically want to be IFR capable/legal. My intended use will be light VFR capability/use and that has been well articulated by several posters above.
Thanks to Scott M., the OP on this thread, for getting the issues on the table and attempting to get the legalities clarified. I would surmise from all the info above that an ELSA, when properly equipped as defined in 91.205, would indeed be IFR legal, and that the two main changes from the ELSA configuration would be the 91.205-required heated pitot and approved IFR navigator source, and I'm considering what I think is a fairly creative Dynon/Avidyne solution for that. Anything other than that and any disagreement with that?
I am fully aware that I could build it as an E-LSA and then change the panel and certain other items the day I get the COA so as to comply with 91.205, but I have no problem building it as an E-AB. I'm not sure why some other posters seem averse to that.
Once I start the build I'll get back into the pitot issue and the fact that a wing mounted heated pitot would technically require an entire flight test series to determine accuracy, a topic for another thread. I'm told that the Rotax 912iS has a higher output alternator which will hopefully handle the additional electrical load needed, I'll research that here shortly.
So, for the archives, do we have clarity on this now?
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
09-17-2018, 02:30 PM
Where in 91.205 do you find a "required heated pitot"?
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
09-17-2018, 03:04 PM
moderator
That's what I get for trusting what others have indicated -- I haven't specifically found it, my apologies. Let's clarify, is it required for IFR operations or just a good idea?
Randy Lervold
09-17-2018, 03:26 PM
Not required.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
09-17-2018, 04:30 PM
The “approved ifr navigator” could be as simple as a VOR, depending on where you’re going. As to the heated pitot, as Gil said, not legally required. You might ask yourself, “Will I absolutely never enter the clouds when it’s below freezing?” You might also ask yourself if your EFIS attitude display requires airspeed data, airspeed or gps, or neither, and how that factors into your risk tolerance.
09-17-2018, 05:38 PM
moderator
Good point, virtually all EFIS systems use either GPS or pitot/static "aiding", most use both to some degree.
Randy Lervold
09-17-2018, 05:47 PM
Stein sells an easy to install alternate static air source switch valve. Cabin alternate air selection with autopilot on will move the plane 60 feet vertically at cruise.
As important as Pitot heat, potentially.
I did get a static block once after a level 5 storm drenched plane from every direction.
Have not tried to find icing.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
09-17-2018, 09:22 PM
Some use “aiding” (fine tuning); some will show a just plain wrong attitude without either pitot or gps data.
09-18-2018, 08:48 PM
I have heard that the ELSA operating limits now preclude IFR operation by incorporating the POH into the OL. Mel, is that true? Mine issued in 2012 allow IFR if so equipped.
The way around the IFR issue on ELSA seems to be build EAB and equip for IFR.
Personally I think the RV-12 would not be a good IFR platform without an autopilot, but I’m sure some would disagree. My Cherokee allows some division of attention when hand flying and sorting out ATC reroutes without looking up from the chart and finding an unusual attitude or new heading. I don’t think the 12 would be as forgiving of momentary inattention.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
