Old 06-26-2018, 09:33 AM
Originally Posted by lr172 View Post
Scott,
I plan to follow this approach on my 10. Can you elaborate on how similar or dissimilar the 10 wing is from the 12 wing? Would you expect the 20* orientation to also work well on the 10 wing. I realize that no testing has been done for the 10 and i am in experimentation territory.
It should be pretty close for the 10 as well but I have never analyzed it because we have pitot mounted ports on both of our RV-10's.
It would be better to be slightly aft of nominal than fwd of nominal. If the port gets near the flow stagnation point as the wing approaches stall AOA, the reading on the indicator can begin reverse and show that AOA is decreasing. I have this issue with my RV-6A because I had to guess at position. I will be adding another port in the future.
Scott McDaniels
Hubbard, Oregon
Old 06-26-2018, 10:56 AM
redbaron redbaron is offline
Default AOA
Even with the wings finished it an easy install
Old 06-26-2018, 12:23 PM
lr172 lr172 is offline
Agreed and this is why i am open the to trying. It will be easy to move the rivet to a new position and plug the old hole.
N64LR
RV-10 in progress
Old 06-26-2018, 12:24 PM
Thanks for the insight Scott! Do you know what angle the 10 wing stalls at? If it is greater than 20* from the relative wind, it is hard to see how the 20* location eould work. Though i suupose the large decent angle near stall speed will keep the relative wind at a good angle down from the chord line.
N64LR
RV-10 in progress
Old 06-26-2018, 02:31 PM
Most airfoils stall at something close to 17* AOA, but I can't tell you for sure what what the correct zero angle reference is on the RV-10 because of the influence of the reflex.
If Steve (designer see's this thread, possibly he would be willing to comment)
Sorry for the thread drift, if a moderator wanted to break this off into a new thread in the RV-10 forum, that would probably be a good thing.
Scott McDaniels
Hubbard, Oregon
