Old 09-25-2016, 11:38 PM
olegusan olegusan is offline
Default Jabiru 3300
Hi,
I'm looking for information about installation of Jabiru 3300 on RV-12.
In particular, I'm interested to see engine attach point modifications.
There are a few flying RV-12 with Jab 3300. I wonder if people modified the engine mount attach points in any way.
I know joedallas (http://joesrv12.com/) has pretty neat modification for the attach points. http://joesrv12.com/Builder%20Log/al_08_01.htm
Did anyone install the Jab 3300 on the airframe without mount points reinforcement?
If so, did you observe any problems?
Cheers
Oleg
RV12 # 877
Melbourne, Australia
Build log:www.RV12.com.au
My DIY Avionics: ExperimentalAvionics.com
Old 09-26-2016, 05:46 AM
Weasel's Avatar
Weasel Weasel is offline
I have an Uncle in Virginia that built one. He and his son used it to get there private pilots license. I flew in it a while back. Very nice flying and smooth running. They are on here from time to time and yes there was some additional forward fuselage beef up points. Joedallas was talking a lot with them when it was in the design/construction phase so if you can get in touch with Uncle Oren you can probably learn how it was done from Joe.
His son used it in the wedding
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1400hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 90 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 09-26-2016, 05:54 AM
TomVal's Avatar
TomVal TomVal is offline
Originally Posted by olegusan View Post
Hi,
Cheers
Oleg,
As you may already know, Pete Krotje, of Jabiru North America sells complete firewall forward kits for the 2200 and the 3000. My firewall with the 2200 installed does not have the reinforcements, however, this engine/prop combination is 35 lbs. lighter than the Rotax. Although it never hurts to beef up the firewall, Pete may have some additional suggestions for you.
http://jabiruna.com/engines/firewall...ts/vans-rv-12/
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 09-26-2016, 12:32 PM
KatieB's Avatar
KatieB KatieB is offline
Originally Posted by TomVal View Post
Oleg,
Thanks Tom, one correction there-- Pete didn't develop a 3300 kit for the RV-12 because he felt it would require too much reinforcement and modification of the fuselage. Of course, the 2200 is lighter and smaller, so he does sell firewall forward kits for that. (Pete is my father-in-law and I helped with the RV-12 project in 2011.)
Oren went considerably "off plans" with his 3300 powered RV-12, but his airplane is gorgeous, and from what I hear, it's a joy to fly.
Katie Bosman Krotje
Sold my RV-3B project...
But RV8 3301 is in the works.
Jabiru J200 flying after restoration and new panel!
Old 09-27-2016, 01:40 PM
Chrysopelea Chrysopelea is offline
Just out of curiosity, how fast does the 3300 powered RV12 fly at? It seems like it might be able to cruise above VNE with the right prop while still retaining good climb characteristics.
A friend of mine has the 3300 in a Sonex, and let me tell you, that thing goes WAY faster than 120 knots! It's a hotrod. I've also seen VW conversion Sonex videos doing high speed passes above 200mph (or knots, not sure, but either way, WAY FAST).
The 3300 also sounds awesome. Sounds like a hotrod idling.
Old 09-29-2016, 07:22 AM
Fearless's Avatar
Fearless Fearless is offline
Default Talked with Pete at Midwest Expo
Katie,
We talked with Pete at the Midwest Expo and he sounded like he might have had a change of heart on much strengthening to do. We are contemplating it but not to the extreme that Oren or Joe has done. The battery will need to go behind the baggage bulkhead to offset weight and the firewall will need to be beefed up at the mounting points. We will talk with Pete again before we totally commit.
Mike
RV-9A Based K6I2
Working on Phase 1
Building RV-12 with brother
Old 09-29-2016, 05:04 PM
joedallas's Avatar
joedallas joedallas is offline
Default 3300
Of course I think the jab 3300 or the new 3310 is a great choice for a alternate engine for the twelve.
The cowl that Pete krotje of Jabiru has designed for the twelve is for the 2200 and the 3300 engines.
I believe that Pete also thinks that the 3300 engine is a good choice for the twelve, however I don't think he wants to assume the responsibility of the mount of the engine on the locations of vans design.
This is something that we have to work out on our own.
The design that Oren and I have worked out should handle the loads that the heavier more powerful and longer arm engine will add.
( This is something each builder has to evaluate on their own ).
This is only my view and not a endorsement.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 09-30-2016, 07:54 PM
bhassel's Avatar
bhassel bhassel is offline
jab 3310? what's that?
Bob
Bob Hassel
NM
Subscription Paid for 2018
Home is where the hanger is...
Old 10-01-2016, 06:07 AM
joedallas's Avatar
Default Jab 2210 & 3310
If all goes well the 2210 and the 3310 will be the new engines from Jabiru.
I think the 2210 should be out soon and the 3310 may be out in 2017
Pete would have more info on this.
Joe Dallas
Bob
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 07-06-2018, 08:39 AM
TomVal's Avatar
Joe Dallas
Slightly off topic...Joe and I are both installing new Jabiru generation 4 engines. I am installing the 2200 (note, not 2210) and Joe is installing the 3300.
Ready for engine start however I made a last minute change in propeller from wood to composite. Joe is going to beat me. I am leaving town for six weeks so will delay initial start until my return.
Joe is about finished with his very highly modified -12...a potential SnF award winner! Looking forward to his posts when ready.
[IMG[/url][url=https://www.flickr.com/photos/165603625@N07/][/IMG]
Tom Valenzia
RV8 (Sold)
