Old 07-04-2018, 08:35 AM
cderk cderk is offline
Originally Posted by PilotBrent View Post
Pledge (personally prefer lemon scent)
Interestingly enough, in Section 5, Van's specifically says NOT to use things like Pledge...
RV10 - #41673
http://n688cd.wordpress.com
N688CD Reserved
1980 Piper Archer II
Old 07-04-2018, 11:39 AM
John-G John-G is offline
Default Plexiglass cleaner caution
Don,
I have been having very good results just cleaning the canopy with a mixture of Dawn dish washing detergent and water. I use two microfiber cloths one soaked with a Dawn + distilled water solution and another to dry off the canopy. I also would suggest wiping in one direction only (with air flow) to avoid any swirls in the plexiglass.
That said, if you feel you must use a plexiglass cleaner please take heed ... not all of the plexiglass cleaners are compatible with the acrylic rear window installed on the older RV-12's so you must read the label VERY closely. Of course, if you have the new plexiglass rear window installed in place of the acrylic window, then disregard this paragraph.
Correction: As Joe so eloquently pointed out in post #14 I've reversed the names of the materials used on the front and rear windows on the older RV-12's. However, the point I was making still rings true ... some of the Plexiglass cleaners are NOT compatible with both polycarbonate and Acrylic materials so read the labels very carefully..
Happy flying,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 07-04-2018, 12:01 PM
rv8ch rv8ch is offline
Default Water
Every airshow I go to I ask the windshield and canopy manufacturers what to use, hoping for some kind of a new miracle product, but they always say the same thing "water!".
Lots of water using your hand (obviously with no jewelry), and a microfiber cloth.
Mickey Coggins
http://rv8.ch
Old 07-04-2018, 12:26 PM
The original rear window was made of polycarbonate. Acrylic and Plexiglas are the same thing. Plexiglas is a brand name. I believe that the canopy and rear window are now both acrylic.
Joe Gores
RV-12 Flying
mfleming's Avatar
mfleming mfleming is offline
Default Hijacked Thread - back on topic
So, you windshield cleaners realize you completely hijacked this thread from post #6 on.
Anyone else have information about the OP question on encountering problems with getting the plastic canopy film off over time?
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 07-04-2018, 12:44 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Yes, back on subject...
I had 20 year old clear plastic on my canopy. It had gone brittle and stuck over most of it's area.
I used isopropyl alcohol soaking and very gentle fingernail action to remove it a small bit at a time. Took a while but it all came off with no damage.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
