Old 01-30-2015, 04:54 AM
Abbygirl1 Abbygirl1 is offline
Default Noise
Absolutely no noise whatsoever in any of my avionics also.......
Dad of an Air Force C-17 flight instructor
Old 02-08-2015, 04:03 PM
Thumbs up Rigid Industries LED pix
Here's a picture of the Rigid Industries LED landing lights. The flood in on the picture's right and the spot is on the left. Excellent product. Well made and BRIGHT and only 2 amp draw. No noise. Also made in the USA. Highly recommended.
http://s172.photobucket.com/user/jaj...=recent&page=1
Old 07-07-2018, 08:24 PM
Ddegange Ddegange is offline
Default Bob Olds Lens
Does anyone know how to get a replacement lens for a bob olds kit?
Old 07-08-2018, 08:01 AM
RONSIM's Avatar
RONSIM RONSIM is online now
Default I tried to find some and ended up
making my own replacements ----- used the old lense to make a wood shape and then used a heat gun to bend plexi around the wood form (I tried Lexan but tougher to work with)-- interesting exercise ---- not professional quality, but no one seems to notice.
Ended up replacing the Olds headlights with Whelen PAR 46 LEDs.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 07-08-2018, 08:14 AM
Aiki_Aviator's Avatar
Aiki_Aviator Aiki_Aviator is offline
Default FlyLeds: a good option.
If going to Oshkosh, have a look into the Landing Lights from FlyLeds....
4 spot, very bright and drop in replacement for HIDs in the Duckworks leading edge light kit. Fully Wigwagable..... (is that a word?? :-) )
In addition, designed and developed specifically for the experimental community.
Extremely good price and outstanding service and support. Im a fan if you haven't noticed....
Andrew Long
#41055
RV10: Happy little Vegemite :-)
Feb 2015: Now fully functional..... and quick
http://www.ozrv10.com
Old 07-08-2018, 11:12 AM
Do you know if any of the Bob Olds Lenses can be purchased? I have the those on my
6A. Thanks Doug
Old 07-08-2018, 12:48 PM
Thanks! Will make them!!
Old 07-22-2018, 04:53 PM
snopercod's Avatar
Default Spot of Flood?
So does the flood or spot work better on a night landing. I have a Rigid SR-Q spot (mounted vertically) on my right gear leg, and am thinking of adding another spot or a flood on the left gear leg. Which do you recommend?
(2018 dues paid)
Old 07-25-2018, 04:40 AM
I have one of each. Typically use both on for any nightime flights. Even leave them on anytime below 10k'. No problems whatsoever.
Old 07-25-2018, 06:15 AM
snopercod's Avatar
If I ever catch your Son at the airport, I'll check them out. I watched his video again but really couldn't see the landing lights on the runway. Since I already have a SR-Q spot on the right gear leg, I guess I should put a flood on the left gear leg. Since they have connectors, I could always switch locations if I needed to. As I said earlier, I really wish they were in the wing leading edges so I could leave them on like you do. A wig-wag setup would be nice, too.
(2018 dues paid)
