Old 06-01-2018, 08:51 PM
n982sx n982sx is online now
Originally Posted by Av8rRob View Post
You will need the wing alignment template for the fuselage.
Nice catch, I forgot about the use of that tool for the fuselage build.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 07-01-2018, 09:43 PM
RV90H RV90H is offline
I am also considering a SB fuselage and QB wings. I know times vary with all builders, but would someone have a rough range for number of hours to build SB fuselage?
Thanks from a first time poster.
Shawn
RV-14 #140473
Old 07-01-2018, 11:30 PM
control control is offline
Fuselage took me 336.6 hours.
(First time builder but I guess by the time I did the fuselage I was pretty comfortable with all ways of construction)
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 07-02-2018, 02:05 PM
StressedOut StressedOut is offline
Did you prime?
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 07-02-2018, 02:40 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Took me 440.5 hours to do the fuselage. Applied water-based epoxy two-part primer to all interior surfaces.
*FTE-full time equivalent (8 hour, 5 days a week)
Examples of mostly fuselage parts following priming, from an uninteresting series of posts on priming at http://rv-14a.blogspot.com/search/label/Priming
E
