Old 06-27-2018, 05:10 AM
TASEsq TASEsq is offline
Default Section 5 - use of tape instead of proseal
Hi,
I am a little confused after reading section 5 and tape instead of proseal. Lots of build logs talk about scuffing and masking the area where the trailing edge will go, to aid the proseal in sticking, but Section 5 is silent on this as far as I can see.
Is this still required if using the tape instead of the proseal?
Can I prime both the skins and the trailing edge piece, if using the tape, as I was thinking otherwise there may be a source of water wicking and future corrosion (as I don’t know if the tape has the same properties as the proseal).
My gut feeling is I should prime both and use the tape onto the primer (perhaps with light scuffing).
What has everyone else that used the tape been doing?
Thanks all in advance. Sorry if it’s been covered somewhere before or in section 5 - I may well have missed it.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Dues paid until April 2019
Old 06-27-2018, 06:43 AM
Z-EDD's Avatar
Z-EDD Z-EDD is offline
Originally Posted by TASEsq View Post
Hi,
Can I prime both the skins and the trailing edge piece, if using the tape, as I was thinking otherwise there may be a source of water wicking and future corrosion (as I donít know if the tape has the same properties as the proseal).
Thanks all in advance. Sorry if itís been covered somewhere before or in section 5 - I may well have missed it.
As I understand it the only reason for using an adhesive here is to hold the skins together until you get rivets in there, since you can't use clecos while back riveting. I used proseal so regarded that as corrosion protection. If using tape I think I would apply the tape over the primer.
Ed Fleming
RV-7- Wings done for now, canoe riveted.
Harare, Zimbabwe
Paid 2017
Old 06-27-2018, 08:45 AM
Bavafa Bavafa is offline
I used tape with great success. In the past I had used proseal and worked great but messy work. The tape, if you have not seen it, is extremely thin and occupies less space than proseal and I personally don't see any concern for moisture retention/corrosion. But I had primed all my surfaces.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
