Old 06-21-2018, 06:33 AM
tracy tracy is offline
Default Flap tape
What is the best(easiest) way to lower the flaps on the 8? I need to replace the tape.
Tracy Willingham
RV-8
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 06-21-2018, 07:53 AM
Mark Dickens's Avatar
Disconnect the flap actuator rods inside the cockpit and the flaps should just hang down where you can do that work
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 06-21-2018, 08:55 AM
KatanaPilot KatanaPilot is offline
Does anyone know a good source and part numbers for this or equivalent tape? I know I can get it from Van's, but the shipping will cost as much as the tape. If I can source it locally, I can get it quicker, as well.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction
Old 06-21-2018, 09:07 AM
I used the stuff Flyboy Accessories sells. Good for other uses too-----cut a big washer to fit around the tow bar hole in the nose pant among other uses.
http://www.flyboyaccessories.com/Pai...ilm-p/2301.htm
Old 06-21-2018, 11:06 AM
Thanks Mark. I would like to talk to you about your beautiful paint job, thanks.
Tracy Willingham
RV-8
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 06-21-2018, 01:47 PM
Jpm757 Jpm757 is offline
FYI. I used the fuzzy side of Velcro tape on the bottom of the wing skin above the flap. Working great so far (110 hrs.) No scuffs or scratches.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 06-21-2018, 02:36 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
In the desert I think that would be a dust magnet and lead to scratches.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-21-2018, 04:02 PM
catmandu's Avatar
catmandu catmandu is offline
I went for 3M Paint Protection Film. Works great, although I wish I had put it upside down on the wing side, vice the flap itself.
Mike C.
Maryland's Eastern Shore
RV-6A bought flying
