Old 06-18-2018, 11:39 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Originally Posted by rocketman1988 View Post
I mounted my pumps on the left side tunnel wall and installed an access panel on the right wall. Made the plumbing easier... canít say how it is going to work as Iím not flying yet...
Did the exact same thing... I can get to the filters and pumps through the access panel(albeit with a few 4 letter words and scraped knuckles).
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 06-18-2018, 02:56 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by 219PB View Post
Aluminum bulkhead fittings through the firewall, low and centered. And why the hole? Some kind of heater box?
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-19-2018, 04:57 PM
219PB 219PB is offline
Dan,
Those are steel fittings. The hole is for the nose gear bolt. I have SS plug that will be sealed in.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2019 Dues Gladly Paid
Old 06-19-2018, 05:18 PM
DanH's Avatar
Dan,
Got it, thanks.
I'm curious...a builder-at-large question. Traditional firewall layouts serve traditional installations. This is EFI, so no engine driven pump. Has anyone thought about moving the bulkhead fittings up high and off to the side, then plumbing direct to the fuel rail, rather than punching through low and centered, in the firewall's hot spot?
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-19-2018, 05:31 PM
I hear you. I did it this way because of Van's heater layout. Wanted to use as many of the factory options as possible. Makes for a clean installation. I realize that this is the hottest spot in a fire event. That is why I installed steel bulkhead fittings and SS braided-fire sleeved lines on the firewall side.
In the event of a fire, I am more worried about the floor of the aircraft, however I am not going to modify that part of the aircraft.
Paul Bonorden
My Builders Website
Victoria, TX
Old 06-20-2018, 11:06 PM
bobhope2505 bobhope2505 is offline
Looks great! Thanks.
RV-14A
Air frame complete
90% done, 50% to go...
Old 06-20-2018, 11:31 PM
Got it, thanks.
That's what I've done with my alt engine install. Throttle cable and most wiring go through a flanged stainless tube above the top left motor mount bolt ( technique described in the AEC book), and fuel through a bulkhead fitting just below and inboard of the same bolt. No stretch, and minimal flex by exiting there with my configuration, with throttle and fuel at top left of the engine. Fuel line follows motor mount to the area near the fuel distribution block.
