Old 03-07-2016, 02:35 PM
PMLviator PMLviator is offline
Default mechanical spar switch
I just installed the mechanical push button spar pin switch. KAI (31B-10 step 5 rev 1) says to use as many AN526C832R8 washers as needed between the pin switch plate and the flange of the F-1248 Arm Rest. I had to use six washers on each screw for spacing, is this the norm?
Old 03-13-2016, 01:54 PM
Leon,
You're probably one of the first guys to use the new design, so there may not be much info out there for comparison. That probably accounts for the lack of forum response.
Rich
Old 03-13-2016, 04:10 PM
RVTrumpet's Avatar
RVTrumpet RVTrumpet is offline
There really is no "normal" so to speak. The amount of washers may vary plane to plane (even left side to right side). It's all about getting the switch in a position where it will be depressed by the pin handle when the pin is properly installed and captured. You gotta do what you gotta do....
A couple RV-12s
Building 8A
NOTE: The information, ideas, and opinions presented in this post are my own and not those of my employer. Build, test, and fly at your own risk.
Old 03-13-2016, 11:09 PM
Thanks Rich an Justin,
I misquoted a AN-8/32 screw, it's actually six NAS1149FN832P washers on each screw.
Old 06-09-2018, 01:33 PM
kevinl4000's Avatar
kevinl4000 kevinl4000 is offline
Which is a #8 (AN960-8) washer.
I also found six (x 4 = 24) washers to be necessary for proper spacing. Hope this helps out the next guy.
Kit #120-666 "The number of the beast"
http://kevinsrv12build.blogspot.com
Old 06-15-2018, 01:05 PM
kevinl4000's Avatar
Correction: six washers on the left side; five washers on the right side. Ugh.
Old 06-16-2018, 12:11 AM
rongawer rongawer is offline
I used 5 washers on each side, so you’re on track.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
