F-601Z Aux Fuel Pump Firewall Doubler necessary with Andair?
tgmillso
Sponsor
Hi All,
I'm still working on prepping as many parts for priming before the temperature drops here, and one part I was wondering about was the F-601Z Aux Fuel Pmp Firewall Doubler. I'm planning on installing the Andair fuel boost pump for my IO-360 per the plan in the link below, except placing two filters in the wing roots rather than in the cockpit.
http://www.andair.co.uk/wp-content/uploads/2014/02/RV7_installation.pdf
If I am to use the Andair pump, I presume the recommended mounting configuration makes the F-601Z doubler redundant, so I don't need to install it? I'm just double checking so incase it is/can be used for some other purpose that I have not picked up on.
Tom.
Yup, that's right...no need for a firewall fuel pump with the Andair in the cockpit and a mechanical fuel pump on the engine, so no need for the doubler.
Hope this helps...
