Fuel Level
jakej
Anyone know if you can use the Vans capacitive plate system with the EI Fuel Level gauge ?
TIA
Jake J
fuel level
You need their gauge that is specifically for capacitance senders. In my previous panel, I had an EI model FL2C for my capacitance senders. There's also a little converter sender for each tank.
Fuel level
If you have done the Capacitive installation exactly to specs in the tank (no shorts!), calibrating the indicator is next. It can be tricky.
I spent a LOT of time to get it right. You can mail me and I will send you a "Calibrating EI FL-2CA for Dummies" that I made out of frustration, because the EI instruction does not tell the whole story - I think! Sincerely
TOM [email protected]
