I was reading the Oct Sportaviation magazine article about the Technam P2010
They talk about this engines ability to run on mogas with up to 10% alcohol.
I don't think the engine would have any problems with Mogas and 10 percent ethanol. (assuming compression ratio allows). The problem is vapor lock and ethanol damaging rubber in the fuel system.
If your fuel system were built to withstand ethanol you should be able to run it just fine. My aircraft runs on MOGAS with ethanol but I have a Subaru engine and fuel system components that are ethanol compatable.
In MN I can get non-oxygenated gas that is 92 octane and has no ethanol. I used it in my motorcycles and small engines. The gas is about $4/gal compared to $5.30 for 100LL. That ought to solve the rubber problem. Changing to non-ox completely cured my '98 Yamaha Virago ethanol disease.
Does anyone have any experience with using non-ox?
