Old 02-20-2017, 08:31 AM
pstraub's Avatar
pstraub pstraub is offline
Default New Rotax Oil Tank Weeping??
Hi all, I could use some advice....I received my new Rotax from Van's a couple months ago. In preparation for the first engine start, I have been adding all the fluids, etc. I noticed a random drop of fresh oil on the floor, directly under the oil tank. It appears to be coming from these strange indentations on the bottom of the tank. I have no idea what these marks are for?? The oil is not coming from the drain plug or washer. I guess I could fill them in with pro-seal, or should I just drain the tank and get it replaced under warranty? Thanks for any thoughts...
Paul Straub, First Flight May 5, 2017
50 hours and counting.....
**2017 dues paid**
Old 02-20-2017, 08:52 AM
Is that where a safety wire hole is in the boss?
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 02-20-2017, 09:35 AM
pstraub's Avatar
Ahh, that would make sense. I guess you would safety wire the drain bolt to that? I am guessing it was cut a little too deep and punctured the threaded hole for the drain plug. Looks like I need a new oil tank?
**2017 dues paid**
Old 02-20-2017, 09:36 AM
DHeal DHeal is offline
Paul -- Those indentations are for the safety wiring of your drain plug to the oil tank. These indentations typically have small holes drilled horizontally through them for the passing of the safety wire. They certainly should not leak -- if they do, it may mean that the hole was inadvertently drilled into the fluid-holding portion of the tank. I would make sure it is in fact leaking before you drain the oil tank and inspect/test that area for a leak. If it is leaking there, that would seem to me to be a ROTAX warranty item. -- David
ps -- Always "double-wrench" that boss/plug when removing/tightening the assembly -- you might mess up the boss/tank bottom if over-torqued.
EAA #23982 - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 02-20-2017, 09:50 AM
pstraub's Avatar
Thanks David, I did hold that boss with a wrench and torqued the drain plug just in case it was loose. I think the tank was compromised when they made the hole in the boss. At least now I know what I'm looking at, thanks for replies.
**2017 dues paid**
Old 02-20-2017, 10:59 PM
A pain in the butt, but you can verify the leak by removing the tank and doing a bubble check under air pressure. If it is a manufacturing defect you should be covered by warranty.
Old 02-21-2017, 05:38 AM
KatanaPilot KatanaPilot is offline
Default Here's another suggestion
Given the issues with 912's and oil changes, air in the system, purging, etc. - I would recommend you purchase an oil system purging/priming kit.
They are available from most of the Rotax parts suppliers - CPS, Lockwood, etc. I've used one for years on our 912 equipped Diamond and it helps ensure that the oil system is properly purged and primed after an oil change. You could use this to pressurize the oil tank before you drain it and check for a leak at the drain plug boss. In my opinion, you will want this kit anyway for future oil changes - go ahead and get it now for troubleshooting your current leak.
Krea Ellis
Locust Grove, GA and Miramar Beach, FL
DA20-A1 Katana "Princess Amelia"
RV-7A under construction
RV-10 under construction
