I have installed a GRT EIS 4000 with fuel flow option. I have also installed a second red cube flow meter in the return line to make use of the EIS return fuel flow function. My problem is that no matter what value I enter in "FlocalR", I can not reduce the fuel flow to zero. (engine off with fuel pump on, still shows the rate of flow returning to the tank, and I should be able to get it to say zero) I have tested both flow meters and they work correctly.
Anyone have experience with GRT EIS 4000 and flow return function?
