Each plane has it's own W&B , it's its a Angle Valve with a Hartzell prop,battery on firewall it's most likely at the forward edge of CG , Parallel Valve ,Catto prop battery in the back CG is going to be toward the rear .
I have a 4 gallon smoke tank in the rear battery location with 3 gallons of oil for ballast until I decide where I want my solo CG . Still playing with it in phase 1
