Bill_H
A new Rotax SB has been issued as of 12-10-14.
http://legacy.rotaxowner.com/si_tb_info/serviceb/sb-912-066ul.pdf
For us RV12s, for 912ULS engines above a certain serial number, the cylinder head is different. (Or if you have replaced a cylinder head, you might have the new type.)
The new head measures the coolant temperature much more directly than the old head. The SB wants you to note that in your records and ensure your instruments show a lower redline coolant temp of 120 deg C IF YOU HAVE the new style head.
