Old 07-11-2012, 05:31 PM
JRo JRo is offline
Default RV-12 avionics
Has anyone found a way to install one or more cigarette lighters for portable devices on their RV-12?
Old 07-11-2012, 05:48 PM
DonFromTX's Avatar
Sure, I felt the need for one over above the map box.[IMG][/IMG]
Retired US Army Officer
Old 07-11-2012, 06:51 PM
Bill_H's Avatar
Bill_H Bill_H is offline
The aviation department of Radio Shack (and probably similar automotive stores) sells a plugin with 2 or even 3 receptacles on it. Of course you have to know your total load vs the fuse to that port. The is even a plugin with a switched outlet, that one RV12 uses to power a pump from an aux tank to the main tank.
Old 02-05-2019, 09:23 AM
AirHound AirHound is offline
Default Std Kit provided receptacle between seats Question?
Question: I didn't build and not sure that KAI points out how/where the Std Aux Power receptacle, located between the seats, is fused?
Doug
Old 02-05-2019, 09:35 AM
The power outlet in the original RV-12 with the D-180 is protected
by an inline 5 amp fuse connected to the battery.
Joe Gores
RV-12 Flying
Old 02-05-2019, 10:00 AM
DHeal DHeal is offline
The Power Outlet on the Skyview version of the RV-12 is fused via a 5 amp fuse located on the instrument panel-mounted AV-50001 Switch and Fuse Module. You can find out how your specific RV-12 is fused by referring to your applicable KAI, POH, or electrical schematic.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 725+ hours (as of Jan 2019)!
VAF donation through June 2019.
Old 02-05-2019, 10:09 AM
pilotyoung pilotyoung is offline
Default power outles
The plans have one mounted between the pilot and passenger seats. I installed dual USB jacks on my panel and wired it to the same circuit as the original power outlet. I bought the dual USA jacks from Stein.
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 100 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 02-05-2019, 10:52 AM
Original power outlet is always powered independent of master switch. Therefore, if you install USB outlet, you will have constant drain of about 10 mAh even with nothing plugged in. I have my mini iPad powered from USB in place of cigarette lighter plug.
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-05-2019, 11:05 AM
Thanks All!
Doug
Old 02-05-2019, 11:22 AM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
That is probably only true for the older D180 RV-12s, The Skyview one is only powered when master is on. Follow wiring from outlet between seats to panel and tap in. Just insure total load does not exceed 5 amps. I installed a dual USB/Power outlets on mine over 3 years ago soon after inspection.
Scott- 2019 dues paid
Got medical back, now building a 7A; N579RV almost ready for finish painting.
RV-12 #120515, N319RV 1st flight 12/2015 now over 280 hours.
RV-9A, 536 hours sold, RV-7 sold, Kitfox sold
