Old 02-07-2019, 12:06 PM
n74846 n74846 is offline
Default Gas Vapor Stain on Canopy Cover
As one of those who tie down, I use a Bruce's canopy cover for protection. Over the years a large black vapor stain has appeared over the vented fuel cap. It looks like black mold. I contacted Bruce's about it and they say they have never heard of it nor received a comment/complaint about it.
For those who use a cover, have you had/seen a similar stain? I cannot believe I am the only one in the fleet to experience this. Thanks.
Steve at BCT
Flying a built ELSA
Old 02-07-2019, 04:59 PM
BlndRvtr BlndRvtr is offline
What type of fuel?
George
Old 02-08-2019, 01:05 PM
Hotscam Hotscam is offline
Same here on both our 12s
Fill the tank and temperature rise will make the vented cap to overflow.
Large blackish stains !!
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
RV10 PH-USN Hobbs 350 hours
Old 02-08-2019, 02:48 PM
I only use Costco Avgas. And don't recall it being filled to a point where it ever overflows.
Steve at BCT
Flying a built ELSA
Old 02-08-2019, 04:21 PM
May not have to overflow to cause your problem. In fact, partially filled tank may be more of culprit. As temperature changes, the air in fuel tank expands and contracts causing fuel vapor to exit the breather hole in the cap.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 459
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
