Old 02-02-2019, 09:04 PM
Default Fuel Consumption
What are you guys seeing for fuel consumption at cruise? Iíve got a little over 800 hrs on my 912ULS and have seen the the burn rate creep up from4.5 GPH to 5.1 GPH at 4200 RPM AND 22Ē MAP over the last 300 hours. Is that what you guys are seeing?
Rich
Old 02-03-2019, 12:37 AM
Are you really flying around are 4200 RPM?
Look here for fuel burn rate... http://www.vansairforce.com/communit...5&postcount=34
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-03-2019, 01:24 AM
Are you running Mogas, and has it lately been winter blend? You will use more fuel in the winter time than summer time, air is more dense due to the lower average temperatures.
Old 02-03-2019, 10:38 AM
DaleB's Avatar
DaleB DaleB is offline
Our fuel burn was considerably higher than what others reported. During our last CI I did the carb inspection, which includes replacing the metering needle, float valves, etc. We also found a bad left choke cable that may have been keeping the left side starting carb from shutting off completely. Afterward our fuel consumption dropped by at least 1/2 GPH in cruise. We'll never know for sure, but think at least part of that was from replacing worn fuel metering parts.
About the only time I see 22" MAP is during descent and in the pattern, though. Couldn't tell you what the fuel consumption is then.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-03-2019, 09:04 PM
Oops! I meant 5200. Math in public overloads my aging brain!😱😝
Old 02-04-2019, 05:45 AM
AirHound AirHound is offline
Dale, what is MAP on take off and initial climb? Doug
Doug
Old 02-04-2019, 10:15 AM
DaleB's Avatar
Have never noticed, to be honest. On takeoff and climb I have the throttle wide open, eyeballs outside and occasionally glance at airspeed. If I EVER get to fly again (it's been a long, long month of cr@p weather here) I'll try to get a look and remember what it is.
Dale
Omaha, NE
Old 02-04-2019, 03:36 PM
AndrewR AndrewR is offline
At 800 hours I'd be tempted to replace the needles and needle jets in the carbs.
Cheap and easy, and a prime suspect if you are seeing increased fuel consumption.
Old 02-04-2019, 08:22 PM
Andrew, I had my carbs overhauled at about 500 hours.
Rich
Old 02-05-2019, 12:30 AM
Did they replace the needles & needle jets? (Probably, but not necessarily.)
Last 200 hour carb inspection on my Rotax was 400 hours, the comment was they'd maybe replace them next time (600 hours).
Even so, your overhaul was 300 hours ago... the manual calls for inspection every 200 hours. It could be worth a look.
Or maybe your flying style has changed? Air filters excessively oiled?
