Old 01-29-2019, 02:56 PM
AeroDog AeroDog is offline
Default Tape to seal the wing root
At OSH a few years back I spoke with a gentleman there with his -12 who had used tape to seal the wing root like the glider guys do rather than the rubber seals. If the wings are removed infrequently, I can't see a down side. It would save me a lot of time with the Vixen file opening the gap up to 3/16th in order to accommodate the rubber seal. Thoughts?
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2019
Old 01-29-2019, 04:03 PM
snopercod's Avatar
Would vinyl electrical tape work?
(2018 dues paid)
Old 01-29-2019, 04:21 PM
smt6 smt6 is offline
Below is what I use. Lasts about a month of constant flying then the adhesive gets a little tired. It’s easy to work around the camber of the wing.
https://wingsandwheels.com/tapes-sea...seal-tape.html
Old 01-29-2019, 05:09 PM
skydiverlv skydiverlv is offline
https://www.cumulus-soaring.com/bowlus.htm
Larry Vandegrift
ULPower 260is
Old 01-29-2019, 06:37 PM
sf3543 sf3543 is offline
Default For what its worth...
I decided not to install the rubber along the wing root and have been flying my RV12 for years with no issues.
There is about a 1/8" gap all the way around the wing root.
I have flown other RV12s and I can't tell any difference in wind, noise, speed, etc.
Steve Formhals
RV6, RV8 (2), RV12 & RV3
A&P, Tech Counselor & Flight Advisor
Old 01-29-2019, 08:02 PM
I put rubber channel on the edge of the wing skin. Still looks great after 7 years. You can get it from Aircraft Spruce. The cross section is a U with about 1/2 wide and a 1/16 center gap.
Old 01-29-2019, 08:17 PM
DaleB's Avatar
DaleB DaleB is offline
I used rubber C-channel from McMaster on mine. Had to trim it some on the top to accommodate the wing rib, but it works fine. If we ever re-paint I may install foam instead.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 01-30-2019, 08:28 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
I too have not installed the wing root seal. Flying for a year now. If I am ever looking for something to do then maybe I will but......I am retired and have way to much to do. Keep flying!
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2019 donation current
Old 01-30-2019, 09:57 AM
snopercod's Avatar
You might try using 3M Primer 94 on the substrate. You apply it, let it dry, then stick on your tape. 3M says:
Promotes adhesion to polyethylene, polypropylene, ABS, PET/PBT blends and other on difficult to stick to substrates
Commonly used for increasing adhesion of film and vinyl graphics in automotive detailing
I used Primer 94 on the ends of my vinyl graphics to keep them from lifting in the air flow.
(2018 dues paid)
