Old 01-22-2019, 11:28 AM
n74846 n74846 is offline
Default Erratic OAT
My OAT is now giving erratic readings, up and down, and does not settle out during flight. Before I either replace, or start taking things apart (I am not the builder), I am looking for ideas where to start. Are there plug connectors to be cleaned, and if so, where are they? Can a new probe be spliced in or does it require a re-wire? Any help is appreciated. Thanks!
Steve at BCT
Flying a built ELSA
Old 01-22-2019, 06:48 PM
It depends on the electronics that are installed. If a D-180, the first place to check is aft of the baggage bulkhead. If I remember right, there is a D-Sub connector that contains the wires from the OAT probe. Take that apart to make sure all of the pins are seated properly and there are no broken wires.
Joe Gores
RV-12 Flying
Old 01-22-2019, 07:54 PM
DHeal DHeal is offline
You will likely find it very beneficial to your maintenance efforts to acquire a set of digital plans from Van's for your version of the RV-12 -- this assumes that the previous owner did not provide the original construction plan set with the aircraft. The physical locations of the various sensors, wiring, and connections are illustrated in the plans. Van's also offers detailed wiring schematics at:
https://www.vansaircraft.com/public/downloads.htm
As I recall, the OAT probe is a two-wire affair with no particular polarity.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 790+ hours (as of July 2019)!
VAF donation through June 2020.
Old 01-22-2019, 10:03 PM
Sorry I failed to mention I have a classic Skyview. I have the plans on disk, but it was unclear where the wires enter harness/skyview. Thanks for the suggestions.
Steve at BCT
Flying a built ELSA
Old 01-22-2019, 10:40 PM
lr172 lr172 is offline
Most common cause would be a poor connection or poor ground. Those type of sensors are not known for common failure.
N64LR
RV-10 in progress
Old 01-23-2019, 08:08 AM
funflying funflying is offline
Default It has happened to me too.
Steve,
I have a Skyview Classic and had an issue with the OAT. The wires from the probe travel back to the ADHAR (the box were pitot and static connect) and connect with a small plug. Like Joe mentioned in an earlier post, mine had developed a poor connection. Since I corrected this poor connection of these wires/pins into the plug I have had no other problems. Good Luck.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 01-23-2019, 08:57 AM
Thanks for the input. I'll start with the connection at the ADHAR, as that is the easiest to reach.
Steve at BCT
Flying a built ELSA
