Old 01-12-2019, 05:15 PM
lewy lewy is offline
Default Matco Brake MHE51B
Hello, has anyone replaced the o-ring in the brake assembly? Mine has developed a drip and need to disassemble, how do you get the puck out of the assembly?
Old 01-12-2019, 05:50 PM
DHeal DHeal is online now
The classic way to remove the piston is to carefully blow air (or fluid) into the brake line fitting on the caliper assembly. Be careful that you don't over-pressurize the piston thus turning it into a projectile!
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 725+ hours (as of Jan 2019)!
VAF donation through June 2019.
Old 01-12-2019, 06:02 PM
rongawer rongawer is offline
An easy way to remove the puck is to pressurize the fluid side. I remove the caliper, place the piston face-down on a firm surface and then use low pressure air into the fluid fitting. Generally a quick puff of 10-15# air does the job.
Ron Gawer
- RV10, N1530G (reserved). Build in progress.
- RV12, N975G, "The Commuter"
Old 01-13-2019, 06:31 PM
Default No leak
Thanks for the info, local mechanic had the correct o-rings and we rebuilt both sides. Had a little grit causing the drip. Thanks again.
Old 01-14-2019, 11:08 AM
You could have Flex Honed the cylinders of the calipers, while the calipers were open, to assure a good, smooth unbuggered sealing surface for the new seals. Always a good idea if an O ring has already been wrecked by a bore with grit in a caliper.
