Old 01-11-2019, 04:27 PM
dweyant dweyant is offline
Default Canopy Repair
All,
One of our RV-12's had an incident (non motion) that has destroyed the canopy.
It will most likely be an insurance claim. Does anyone have any recommendations for someone that would be willing to do the repairs?
Also, the plane is not local to me. What are the chances that a replacement canopy could be built using another RV-12 as a template and have it fit?
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 01-11-2019, 06:13 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
If the frame is good, strip it all off and start over. The KAI will guide you thru the entire process and includes fiberglassing templates. Order replacement parts for a complete rebuild.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
Old 01-12-2019, 07:41 AM
Dave12 Dave12 is online now
Originally Posted by dweyant View Post
All,
-Dan
I would not attempt this if you really want a good fit and seal.
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying
Rans S21 Outbound (Coming soon)
Old 01-12-2019, 09:19 AM
DaleB's Avatar
DaleB DaleB is offline
As I recall, if you look at the cost of buying and shipping the canopy, adding the frame in the same crate is not a big shock. If you're already shelling out for the canopy... starting with a new frame could save a lot of work. Plus you won't have to try to line up the holes perfectly. Or you could just Sikaflex the canopy on and forget the screws.
We had a damaged canopy and the frame was broken at a corner weld. Rather than stripping down the frame and getting the frame TIG welded, I decided to just replace the whole thing and save the teardown and cleanup work.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 01-12-2019, 05:22 PM
KALEWIS's Avatar
I think the frame is rather pricey .... May depend on what the insurance will actually cover
RV-12 #328
Old 01-12-2019, 05:28 PM
DonFromTX's Avatar
Another thing to consider, my frame was a long ways from a fit to the fuselage, took LOTS of bending and forming to match the rest of the plane. Using the old frame, especially if not damaged, might be a better choice.
Retired US Army Officer
Old 01-12-2019, 08:37 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
My frame fit perfectly just needing a nylon spacer washer added to each side at the front pivot. I guess they vary. The 12 frame was unlike the 7 and 9 slider frames that needed lots of work to get just good enough on my other builds.
Scott- 2019 dues paid
Got medical back, now building a 7A; N579RV almost ready for finish painting.
RV-12 #120515, N319RV 1st flight 12/2015 now over 280 hours.
RV-9A, 536 hours sold, RV-7 sold, Kitfox sold
Old 01-13-2019, 04:22 PM
My frame was a good fit. The fiber glass may be intimidating to a beginner, but after you realize you can always sand it down and start over you’ll see it is probably one of the most forgiving processes in building the kit. A little 5 minute epoxy will put the foam back together if you break it or make a mistake cutting it. The important thing to remember is that the foam is just a contour mold that the fiberglass lays on top of. God bless micro balloons and epoxy slurry for hiding cosmetic glitches!😝
Old 01-13-2019, 09:16 PM
AirHound AirHound is offline
Dale, if the day comes for me to replace canopy or rear glass, please describe how sikaflex negates the need for screws? Thanks Doug
Doug
Old 01-14-2019, 08:28 AM
DaleB's Avatar
We've already done the rear window with Sikaflex. We'll be doing the canopy this Spring when it warms up enough to do the fiberglass work, I hope. I'll post pics. We've got the frame and canopy ready go, just need the time to finish it.
Dale
Omaha, NE
