Old 12-28-2018, 07:44 PM
Brett H Brett H is offline
One question about fitting the Aft Window.
Page 25A-03, revision # 1 step 1 and 2 describes attaching the Aft Window to the Roll Bar Frames. In particular, that one is drill # 40, followed by final-drill # 36 and then tap 6-32.
Since section 5 says that the plexiglass should not be drilled or the holes enlarged with a twist drill, what are people using to drill and final-drill these holes?
Thanks.
Brett H
Columbus, IN
Old 12-28-2018, 10:01 PM
DaveWelch DaveWelch is offline
Default Drilling Plexi
Hi Brett,
Working from memory here, the Instructions called out a fractional sized Plexiglass bit for the canopy. The plexi bits have a different shape that is less likely to “dive” eagerly into your canopy only to bind up and fracture it (the canopy). Find, order, or borrow the correct sized plexiglass bit if at all possible.
Now, for the drill and final drilling then tapping you mentioned, I think that refers to drilling the roll bar, NOT the canopy. I could be wrong, but recommend you re-read the instructions carefully.
All the best for the new year,
Dave.
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 12-29-2018, 06:01 AM
tomkk's Avatar
tomkk tomkk is offline
Don't remember the size (#27 seems to ring a bell) but all my drilling in Plexiglas was with a special Plexiglas drill.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK in progress
Old 12-29-2018, 10:24 AM
I used commercial drill bits and picked one that made a hole that allowed the machine screw to turn freely (no stress on the plex from an interference fit). The biggest thing to prevent plex cracking is make sure it’s warm. I recall drilling a smaller pilot hole before final drill to size.
Old 12-29-2018, 06:02 PM
Thanks for the responses.
Let me refine my question.
Regarding drilling with a # 40 drill followed by final-drilling with # 36 drill before tapping. I can not find # 40 plastic or diamond drill. The smallest plastic drill that I can find is a # 30.
So, are people just using a twist drill and making sure that the plastic is warm?
For the final-drill of # 36 I can get a reamer.
Thanks.
Brett H
Columbus, IN
Old 02-10-2019, 04:25 PM
AeroDog AeroDog is offline
Looking at 25A-03, it appears that both the plexi and the underlying aluminum structure are being drilled in the same operation. Possibly I'm reading this wrong. Can aluminum be drilled with a plexi bit?
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2019
Old 02-10-2019, 05:40 PM
daveyator daveyator is offline
The plexi bit will continue through the roll bar material with no problem. A recommendation here is to drill both the window and the roll bar to the tapping size first. Then the plexiglass can serve as a tapping guide to ensure the holes are nice and square to the roll bar. Disassemble,then do the final drilling of the holes in the window with the larger bit.
You don't really need the precision of a number drill here. A little bit oversized is better. My tool kit came with plexi bits in 1/8 and 5/32. These worked for me.
DaveH. 120485
