Old 12-02-2018, 04:55 AM
David Fuchs David Fuchs is offline
Default New Builder RV-12iS
I ordered my kit, Empennage/Tailcone on 28 November and I am now in the Tool purchase stage. One question that I have please:
Do I need a Rivet Gun,
Thank You
Old 12-02-2018, 05:11 AM
rgmwa rgmwa is offline
Thank You
No, but you will need a pneumatic rivet puller, a hand rivet puller (PRP26A is very good), and a hand rivet squeezer Cleaveland Mainsqueeze is a popular choice, but Tatco is also good. Have a look at the Cleaveland and Isham RV-12 tool Kits
rgmwa
120346
Old 12-02-2018, 06:22 AM
Default Tools
Thank You Sir
Old 12-02-2018, 11:31 AM
rv9builder rv9builder is offline
Here’s a link to a PDF file for Section 3 of the manual. Page 03iS/U-02 has a complete tool list for the RV-12iS.
https://www.vansaircraft.com/pdf/rev...2iS_03iS-U.pdf
Updates to the manual, service bulletins, notifications, etc. can be found at this link:
https://www.vansaircraft.com/public/service-rv12iS.htm
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 12-02-2018, 04:14 PM
randylervold's Avatar
randylervold randylervold is offline
moderator
Default Pneumatic squeezer
And a pneumatic squeezer, though not necessary, sure makes the work flow faster. I've used mine a fair amount already just in the VS on my -12iS.
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 12-03-2018, 11:34 AM
rcarsey rcarsey is offline
agreed. Early on I was being cheap and skipped a pneumatic squeezer.. Eventually I broke down and bought a used one from e-Bay.. I kicked myself in the butt for not having bought it earlier.
When you put the 1 million rivets in the tail's rear bulkhead, you'll be kicking yourself in the butt too.
and agreed on the PRP26A rivet puller.. and of course a pneumatic blind rivet puller too.. I got a blue one from Harbor Freight.. good enough.
Add a #17 or #19 drill bit to the tool list (i forget which.. whichever one is missing from the list). Also a #6 screw dimple die set (if you'll be installing landing lights).
Old 12-03-2018, 11:41 AM
Mel's Avatar
Mel Mel is offline
I've told you a trillion times, "Don't exaggerate!"
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-03-2018, 11:44 AM
Default Thank You all !
Once again, I thank you all.
Old 12-03-2018, 03:38 PM
Timberwolf Timberwolf is offline
Instead of a pneumatic puller, you may consider the Milwaukee 12v puller. Best tool I purchased this year. No hoses to get in the way and will pull with only 1 squeeze where most pneumatics take 2 or more due to a short stroke.
https://www.homedepot.com/p/Milwauke...B&gclsrc=aw.ds
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P in progress
Aero Engineer, A&P
Old 12-03-2018, 03:48 PM
moderator
That looks like an excellent solution, does it always fully complete the pull with only one trigger stroke?
Randy Lervold
