Old 02-06-2019, 06:06 AM
DaleB's Avatar
DaleB DaleB is offline
I can't get twisted around far enough. I mean, I can see it, but not well enough to get more than a rough approximation of what half or quarter of the range it might be indicating. And with two much more accurate indicators in front of me, I haven't really tried that hard.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-06-2019, 08:17 AM
skydiverlv skydiverlv is offline
Calibrated at same time of Dynon calibration. The float arm was adjusted to provide accurate low level indication. I can quickly cross check Dynon and time in flight.
Larry Vandegrift
ULPower 260is
Old 02-06-2019, 10:07 AM
[quote=skydiverlv;1322643]Calibrated at same time of Dynon calibration. The float arm was adjusted to provide accurate low level indication. I can quickly cross check Dynon and time in flight.
Excellent... How did you make stencil?
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 02-07-2019, 07:40 AM
[quote= Excellent... How did you make stencil?[/QUOTE]
I cut a paperboard blank to mark indicators while filling tank then sent to AircraftEngravers.net to match the panel overlays. .010 lexan reverse engraved. Any color combination you desire.
Larry Vandegrift
ULPower 260is
Old 02-07-2019, 11:45 AM
Can you reference job or invoice # so I can contact them and not have to re-invent the wheel... so to speak?
Hinckley, Ohio
EAA #499867
Old 02-07-2019, 03:34 PM
dbhill916 dbhill916 is offline
ditto!
[I just learned something about this bulletin board system. it will not allow me to publish anything that has less than 10 chars. Hence this meaningless addendum.]
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 02-07-2019, 11:41 PM
Same here.
Old 02-08-2019, 02:47 PM
Unable to locate specific invoice for this particular order. I do have two other invoices that indicate customer# of V537-XX with job number -01 & -02. I would assume the fuel tank placard would be either -03 or -04. Be aware that if ordered, your placement of gallon indicators may need adjustment for accuracy related to float arm angle. Also, the invoices I have show .020 lexan, not .010 as stated in previous post.
Larry Vandegrift
ULPower 260is
Old 02-08-2019, 05:14 PM
Thanks Larry. I have contacted Engravers.net and asked them if they can search their job files for this fuel placard.
I'll post price when I hear back from them...
Hinckley, Ohio
EAA #499867
Old 02-10-2019, 05:58 AM
AirHound AirHound is offline
Would they have the fuel gage indicator on file I could order? For gross indications!
Doug
