Old 12-23-2014, 07:49 AM
jsenft jsenft is offline
Default 11 x 17 Binder
Does anyone know the manufacture and where to buy of the light blue binder used to hold the plans? I can find many other 11 x 17 binder but they all have metal tabs not the nylon tabs like the Vans binder.
Old 12-23-2014, 11:06 AM
FredMagare FredMagare is offline
Default Binder
I found this one: http://www.amazon.com/Cardinal-Premi...s=11x17+binder
Fred Magare
GySgt, USMC (Ret.)
Frederic.magare "at" gmail.com
RV-9A SB Fuselage / Finish Kit on-hand
[Engine and CS Prop still to acquire]
Old 12-23-2014, 12:09 PM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
A cheap and fast way to do an 11x17 binder is using two cheap regular binders, cut the covers of one and cobble them to the other to get the 11x17 format.
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 12-23-2014, 04:12 PM
Mitch757 Mitch757 is offline
I bought a couple of 3 ring 11 x 17 from Staples but Vans also sells the original ones.
Old 12-25-2014, 08:43 PM
daviid daviid is offline
i bought mine from Staples as well.
David King
RV-10 #41517
N484DK (Reserved)
http://rv10.daviid.net
Old 01-24-2019, 05:44 PM
randylervold's Avatar
randylervold randylervold is offline
moderator
Default RV-12iS plans
I just received my wing kit and the plans did not come with another binder as I was expecting. My assumption is that Van's expects us to just keep adding plans to the existing binder, correct?
Seems like that slant-D ring binder someone mentioned above would be a better way to keep the drawings, anyone tried it, and did you use 1", 1.5", or 2"?
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 01-24-2019, 06:15 PM
Hwood Hwood is offline
I picked up a 1" binder from good ole Amazon as well as a 17" clipboard. The technique here is to pull a page or two out of the binder and put it on the clipboard as work progresses....and when a page is complete, put it back in the binder. Works pretty nice as this gives me the ability to carry the clipboard around the shop as things go along. Also, at the pace that I'm moving, there's not a lot of page swapping going on!
Just another technique and 2 cents....
Hwood
N469SH / "Crazy Woman" (sold)
Working on Another -8
Exempt but paid
Old 01-24-2019, 07:57 PM
Tony_T's Avatar
Tony_T Tony_T is offline
I used a 11X17 slant-D ring. I have a 2" and have very little room left in it. There are more pages in the plans now, so get a 2" at least.
Tony
RV-12 #202 -- Flying
Old 01-24-2019, 08:36 PM
rv9builder rv9builder is offline
I have a 1-inch 11x17 D-ring binder. I like the smaller size, but I just keep the plans for the kit I'm currently working on in it. It's nice being able to take out the drawings as you need them.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 01-25-2019, 05:16 AM
mturnerb mturnerb is offline
I got a large slant-D type binder (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and never looked back. So much easier to flip around, pull a sheet out as needed, and keep it laying flat on a table. As you progress through the build, the "fixed" binder becomes more and more unwieldy. I also bought stick-on tabs to easily find sections of the manual (https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1).
Turner Billingsley
RV-14A In Progress
N14VB Reserved
