Hi everybody!
We are on to install the Rear Seat Rudder Pedals on our RV-8 QB.
I?ve got a question concerning the F-8117 Guide Bracket installation. We found pre-drilled holes on the bottom of Bulkhead F-804. I think these holes are for the nutplate installation, right?
We copied these holes to the top of the F-804 Bulkhead. If we install a MS21051-L08 nutplate (like shown in drawing OP-5), the hole doesn?t align with the second screw in the F-804 Bulkhead. The K1000-08 would fit perfectly. How did you do that? Maybe the drawing is not the latest revision?
Does every RV-8 have these pre-drilled holes in the bottom of the F-804 Bulkhead?
By the way ? what is the right drill bit for the screw hole?
Thanks for your help!
Kind regards
Anna
Kind regards
Anna
