turbo
the plane went thru a few strong storms in st pete fl last weekend. the end result was a vfr departure with the vsi and altimeter all over the place. when i got home i pushed back from the static line near the panel area and saw a few drops of water exit the static port. sure glad it was a vfr flight. any ideas on installing a cockpit alternate static port hookup? always learning.
