Dumb question about switch lights
Dugaru
Okay so my RV-9A has these lighted rocker switches
http://www.rvpilot.com/RV9Apanel/out/PICT1218.JPG
Which, based on the builder's log (which is still available on the web! truly a bonus!!) I believe to be Honeywell products. Several of them have burned out lights. I've obtained what I think are the correct bulbs, based again on the builder's website:
https://www.alliedelec.com/view/search?keyword=AML91LA73
Here's my dumb question: do you just sort of pop the caps off to change the bulbs, or is there some more involved procedure?
Thanks!
Doug
Honeywell AML
Those are indeed AML switches. There's a small depression in the end of the switch operator that you can get a fingernail into to pull the operator off. Just push to snap them back on. To remove the bulb, gently pull the metal tab which will push the bulb's base out of it's receptacle in the switch body. The switches will take a generic miniature wedge base bulb which should cost about $0.35 a piece. Allied seems very proud of their own ones at four bucks a pop! If you want to go the LED route instead, the equivalent lamps can be purchased online by searching for T 1-3/4 wedge base LED. Most of the LEDs I've found are a harsh bright white in the 5000K range. I find these a little hard on the eyes in the cockpit. The "warm white" hue is 3000K and is a bit harder to find but here's a link to a source for these at $0.95 each. https://www.superbrightleds.com/mor...-1-led-miniature-wedge-retrofit-car/226/7259/
Thanks all!
Can?t tell you how much I appreciate the info. Let?s just say understanding and fiddling with small electrical components is not my specialty. :)
